Oil viscosity question
A bottle of STP will generally jump you up one grade with the common thinner oils, on something already so thick as SAE 40 not sure. Thicker though. 🤷‍♂️
But you could thin it back down with MMO. 🤣
Naw I need it thick. It's my old tractor. It's getting sae 50 next time.
it depends on what you add it to.
if you add STP to a thin oil it will have a bigger impact vs adding to a 40-50wt thick oil.. as the viscosity difference between the 2 is greater when adding it to thinner oil.
Since straight-weights tend to already be at the upper end of the grade, you’d most likely get at least a thick 50-weight oil.
It won’t hurt an old tractor in the Cali desert!
