Originally posted by Alan:
1. He states one of the major advantages of synthetic oil is it's roughly 700 times stronger then dino in shear strength/stability(ability to stay in the bearings under extreme pressure he was saying).
2. He also stated less engine wear on a cold start due to synthetics being more "slippier".Able to move throught the engine more easily.Less wear at normal operating temperature due to easier flow with a synthetic also.
3. The guy asked if it mattered what brand of snythetic he used,response was something like "no,any one of the major brands is fine".
4. Another guy called in asking about upping to a 10W40 over a 10W30 due to a slight consumption over a 5K OCI(car had over 270K with M1).He answer basically said that he was sacrificing flow to all the internals over a small oil consumption that was normal in new motors.
5. What say you guys?
I'll bite...
1. Frankly, I don't care if a full-synthetic has 700 times the shear strength relative a mineral oil. If we were simply using base stocks as engine oils, this would be great. But of course, we don't. I'll take the finished oil with higher HT/HS numbers...that's the one that will provide me with better shear strength and ability to maintain a hydrodynamic film under high loads.
2. Less wear at startup deals with running a low-viscosity oil, and, of course, synthetics have much better low-temperature properties and thus will give you an oil that will "pump-up" easier and faster. Also, the barrier/extreme pressure additive package comes into question. A fluid film doesn't exist (well, at least much of one) in the top end of an engine on cold start, so the additives will be relyed upon to protect the engine.
3. OF COURSE IT MATTERS what kind of synthetic you use...there is no way you can honestly say a cheaply-made GIII like Syntec is the "same oil" as a Amsoil, Redline, Schaffers, etc...
4. Bull...unless you're driving in a racing applicationt that requires extraordinary amounts of flow, any amount of fluid-lubricant flow decrease when swithing to a higher-vis. oil is irrevelant.
5. I say Mr. Goss really doesn't know a great deal about oil...simply sayin' a bunch of B.S. that, as sad as it is, a bunch of people will buy into.
