Well, I made a typo in that last post, I meant to say "Silicon level SHOULD increase" after a filter change, but apparently you couldn't deduce that from what I've said so far. Are you taking your Centrum for Seniors Vitamins?
Here we go again, just like a dozens other times. You can't win the debate so you start putting words into my mouth.
No, it's more like you believe that when it comes to anything associated with filters, you're the last word on the subject. However, I've seen enough stupid stuff posted by you to take what you say with a grain of salt.
We'll get back to this later.
No, it is not fact. Are we even sure that both air filters in question are identical?
Well then, you're contradicting yourself.
But they didn't, so some mechanism introduced less silicon, possibly the environment changed, less air volume ingested, or there was lab variation. There's also the possibility that air is ingested through the dipstick tube due to the PCV system, and the evironment plays a bigger role than you envision.
I didn't make it sound like anything but what it is. Ever live next to or in a desert for an extended period of time?
Good for you. Now, why are YOUR silicon levels so high? Explain that one for us.
Now who's full of beans on this subject. Never seen one anomaly, heh? Yeah, right, get off the crack pipe. And there's worlds of differences in the quality of filtration systems in commercial heavy duty engines and passenger cars.
Interesting that they didn't spot mine. SWHeat, did they spot yours? Maybe we should take a walk over to the UOA section and see how many they spot there.
Well that's very weasle worded and open to interpretation. After you asked them if it's not normal, asked them if they've ever seen it happen.
My data and SWHeats data says you're wrong. And I'm sure we can find a few others in the UOA section. I believe the burden of proof is on you. Get three labs to sign and notarize a statement that they've NEVER seen a decrease in silicon after an air filter has been replaced. No if, ands, or buts.
And here's a few more points. Were talking about a couple ppm at the low end of the scale. You believe were not going to see any lab variation in a $20 UOA? And if this couple ppm of silicon is so significant, we should see certain wear metals follow the silicon levels, but we don't.
Quote:
And it should be retested. But you would never admit the lab would need to resample would you? No you'd rather argue.
Quote:
You have a lot of knowledge about various things but you are the most argumentative person on this forum. So much so, I think you'd rather argue to prove something to yourself.
Quote:
And your full of beans on this subject.
Quote:
Regardless of driving condition a new air filter WILL let through more contaminant. Fact.
Quote:
SWHeats numbers show no leaks or anomalies that would indicate any problem with to much contaminant getting through from his three samples. Fact.
Quote:
But when he changed air filters his silicon should have went up. Fact.
Quote:
I have driven in dusty conditions myself. You make it sound as if that is the be all end all.
Quote:
I have driven freeways and city driving. Made not one iota difference in a new air filter showing increased silicon levels. Never..i'll repeat never..did the silicon level ever go down after change of air filter. But I never had any leak or problem. I did use different oils, petroleum based, then switched to semi-synthetic in my 1996 Taurus. Switched to Mobil 1 in my 2003 Taurus.
Quote:
I have looked at loads of oil anylsis reports because we used to sell that service. I have seen fleet after fleet of heavy duty engine analysis reports. And the same held true for them. When they changed the air filter(s) the silicon went up.
Quote:
Any lab who does analysis and sees thousand of samples per year can determine when silicon goes up to much because of some problem in air induction as opposed to just changing the air filter.
Quote:
And I am willing to state --for the record- that any lab will say it is not normal for silicon to go down after changing the air filter, when there was no problem in the previous sample ( as with the one of 10 at 30,000 miles) regardless of the "air quality" conditions of where the car was driven.
Quote:
So there you go..anyone want to call their lab and ask instead of 427Z06 bleating on and prove me wrong.
Go for it..
Post what lab you called and what the "experts" say.
