Parroted saying when discussing 5w20 vs 0w20
wemay
Site Donor 2023
Everglades
I may even have parroted it in the past as well...
"The reason brand X recommends 5w20 is because they want to allow you the use of Conventional oils whereas brand Y wants to insure the use of at least a blend with 0w20."
Has there ever been any substantive evidence of this or is it just opinion?
wemay,
I've never seen anything anywhere that substantiates that but have seen it many many times on BITOG.
I think it's bunk...as synth blends can be 0W20...
I agree. Even more so now that that most TDS list 5w20 as a "blend" as well.
By brand I guess you mean vehicle makes? I don't know the answer. I do know that as regards Nissan OM recommendations for a 2017 Rogue and afaik their other models, Nissan recommends 0w20 or 5w30, completely skipping 5w20.
No logical reason to it. Go figure.
I have often and am still wondering the same thing and have discussed this matter in this forum.
Mainly due to having a remaining small stash of QSUD Full Syn 5W20 on hand and would like to use it up in either or both vehicles in my signature(Honda/Nissan). Neither vehicle allows for a 5W20 in the OM, even in a full synthetic oil.
Honda mentions ONLY 0W20 while
Nissan mentions 0W20 syn, 5W30/10W30 dino.
Hmmm,
CB
Don't forget fleet vehicles. Those vehicles in that market are partly sold on maintenance costs. It's true. I remember a conversation with a government fleet chief one time where he said the obvious: "When considering buying 400 of vehicle "A' vs. vehicle "B", we consider: 1. Purchase Price; 2. Maintenance Cost; 3. Residual value in 5 years; 4. Warrany Negotiated for this deal."
With that, allowing 5w20 allows you to use the cheapest Group2 oil you can scrape up. ...... A 0w20 is at least a syn blend and adds some cost. Not much to consumer John Q. Clueless, but it adds up in a competitive fleet deal, along with other things like tire replacement costs, etc., all that.
Some engines are more prone to causing permanent shear as well. The cheapest syn blend 0w20 has a thinner base oil and more VII.
Also, if the engine maker did their durability testing using 5w20, they are likely to recommend the same weight to buyers, especially if the "0w" part isn't considered a necessity with the oiling system.
It does appear GM has asserted their dexos1 0w20 these days though, since I don't know what new GM vehicle uses 5w20 any more.
Hmmm,
CB
Now if they would just cut out the 0w20 as well the world would be a little tiny bit better.
In our 2015 PathFinder OM it says to use synthetic 0W20 or mineral 5W30 which is why I use a full synthetic 5W20.
Ha! the only sensible thing to do.
ðŸ‘ðŸ»ðŸ‘ðŸ»
The only thing I can offer is what it said in my owners manual for the Highlander... "A 5w20 may be used if 0w20 is not available, however 0w20 should be used at the next oil change".
That to me would suggest they are looking for a synthetic and not a semi-synthetic / conventional 20wt. Also interesting when they changed to 0w20 they increased the OCI from their standard 5K Miles (8,000km OCI) to 10K miles (16,000km).
Observations as to why but not proof.
Then you have Chrysler using the PentaStar engine and calling for 5w20 in some and 0w20 in others.
Unless they expressly state it, projecting what they "might" be inferring because of a single specification point is silly.
Originally Posted by Donald
Subaru 2.5 engine requires 0W20 synthetic and not a TDI engine.
As you probably know, the Subaru manual is always the subject of numerous discussions here!
Quote
0W-20 synthetic oil is the required oil for optimum engine performance and protection. Conventional oil may be used if synthetic oil is not available.
*If 0W-20 synthetic oil is not available, 5W30 or 5W-40 conventional may be used if replenishment is needed but should be changed to 0W-20 synthetic oil at the next change
Subaru also skips 5W-20, but I believe the entire oil blurb is more due to not having the information written by a lubrication expert than recommending "synthetic" or "conventional" since both terms are used.
What if I do not want optimum engine performance and protection? Why not allow 5W-20? Why allow 5w30 conventional and not 5w30 synthetic for replenishment?
What is it that edhackett says?
Quote
Never attribute to engineers that into which politicians, lawyers, accountants, and marketeers have poked their fingers.
I do the same, except that my owner's manual specifies 0W-20, or if that's not available, 5W-20 (unspecified whether synthetic or not) for half the normal change interval. I don't know any reason synthetic 5W-20 wouldn't be at least as good as same-brand 0W-20 in a mild climate, aside from a very small hit to warm-up fuel consumption.
Originally Posted by Pinoak
Originally Posted by Nederlander75
0w20's the Devil.
No no my ex wife is the devil.
One man's ____ another's____?
I had a different experience when working in the government fleet industry. The fleet I worked for purchased vehicles - exclusively American manufacturers Chrysler, GM, Ford - and kept those vehicles until roughly 120,000 miles, then auctioned them. Oil was not a concern or consideration. Oil change intervals were 7,500 miles (based on testing/cost analysis) and conventional oil was used (5w30/5w20). There was never a concern of whether oil met specs or warranty considerations. The real concern was proprietary manufacturer information regarding engine management. If manufacturers would not provide that, which almost happened only once (Ford), their vehicles would not be purchased. We had to have their repair information - not just information from Alldata or Mitchell - but manufacturer proprietary repair training, scan tools, updates, access to their data. That was a must.
Tires were of no concern whatsoever, the government had a contract with Goodyear allowing us to purchase tires almost at cost. So cheap that the entire fleet would not purchase alignment machines because tire wear was of no concern, we'd just replace the tires. If something major came along and we absolutely needed an alignment, we'd sublet it out.
Surprisingly there was very little major engine failure or repairs due to the longer oil change intervals using only conventional. Most engine repairs came from Dexcool issue with intake gaskets (GM), vacuum leaks (Ford), EGR carbon buildup/check engine lights, evap leaks, crank sensors, gasket leaks...but very little internal engine issues. Chryslers were overall the worst, by far. Issues from bumper to bumper. But still very little engine issues, even with them. Transmissions?? Oh Chrysler...we would lose a Chrysler transmission almost once a week.
I saw a lot of fluid abuse in those years. Lol. Working in a fleet I really got to see the capabilities of fluids...and their ability to be abused and neglected. There were no considerations for fluid changes (outside of engine oil). Dexcool was the only coolant we'd usually change (only because of engine repairs/cooling system repairs). Ford never seemed to have coolant leaks - I remember thinking...wow, Ford at least has their cooling systems figured out compared to GM. The vehicles were taken out of service at 120,000 miles, so most likely the issues and problems from fluid neglect weren't felt until a little later. One thing I learned from working in a fleet, it's no nonsense, and they will push fluids to the max...and beyond.
0w20's the Devil.
So, which would you rather eliminate -- 0w-20 . . . or your X?
