c3po, you need to use the quoting button so we can distinguish what other people have stated and what your own comments/opinions are. I have had a difficult time separating the two.
You might say for example: QUote from Molecule
Quote:
My comment: ........
Quote:
Molakule, I see that you have used Neutra in your engines and outdoor equipment, but I could not find any posts where you have stated that you used arx in your engine, any reason you would favor Neutra over arx in your engine. I see you have used arx as a maintenance dose in your outdoor equipment, aren't you worried about Neutra and arx competing against one another in your outdoor equipment.
I never had any discussions with the member who started this thread.
As far as independent tests, since Gary Allan loves MMO and I am getting good results, so I see no need to test MMO.
Molakule, I will say that Neutra has been around for 40 years, it can be used in the gas and oil just like MMO, therefore since arx has only been around for 10 years or so and cannot be used in the gas, I feel that Neutra and MMO have more in common than arx and Neutra.
I also gather since you put Neutra into your car engines as opposed to arx then maybe you think Neutra is a superior product to arx or maybe it does the same thing as arx but at a cheaper price.
I have posted on BITOG that I had used ARX in the oil for other than maintenance doses. In my past two Suburbans with SB 350's which were bought used, I purchased and used ARX and it cleaned the engines as indicated by pulled oil pans, and compression restoration. I have also stated that the maintenance doses seem to increase oil lubricity since my mileage went up, which I attributed that result to the only OTC add which was ARX.
BTW, in addition to my academic training, I am a wrenchead as well.
AT one time I ordered (and payed for in full) 5 gallons of ARX for testing as a potential additive in our PCMO's. I found ARX to be an excellent detergent and cleaner, but at the time, we coud not afford to incorporate this component without hurting our pricing sructure for lubes. Franks ARX formulation was both innovative and passed all our tests for engine cleanliness. His chemistry was based on a mix of esters that I believe to be very approriate for cleaning of engines, transmissions, and other machines. As I too was an entrapenuer, I thought his Internet sales situation was unique and appropriate for educating potential customers.
Neutra History: My experience with Neutra goes back to when Bob Winters (the original BOBIstheOilguy) introduced me to it since he was a rep for Schaeffer's at the time. I lived on a mini-ranch in Kansas at the time and bought a small truckload of lubes and stuff to test and try out. I also gave away some product to local ranchers to get them interested and help Bob's sales. Bob is a fantastic guy and a great backyard experimentor.
I also did some flammability and deposit testing with Neutra and LC20, since we had a discussion going on here about deposits and flash points of the two products. It was a fun test.
Sorry dude, I fail to see the logic here. Time in the market has nothing to do with performance. Neutra, MMO, and ARX are three entirely different chemistries. Neutra and MMO are what many like to call "aromatic hydrocarbon" solvents (AHS). The only correlation between Neutra and MMO is that they are AHS, old school chemistries, and can be used both in engine oil and fuel systems.
ARX is a tri-ester formulation for cleaning engines, hydraulics, transmissions, and gear boxes using more modern chemistries.
If you do some more data and quote mining, you will see these same statements used over and over.
Don't assume anything about my intentions or history.
Before I knew anything about ARX I used LC20 and Neutra in lubricating oils, and FP60 and Neutra in my fuels.
When I see a more modern chemistry come on the scene, I try to test it to see if my testing supports the claims made.
I don't think Neutra OR MMO will ruin your engine or fuel system in the prescibed dosages. But what scares me is this mentality of, "a little bit more than prescribed wont hurt," or "what the heck!"
I think ARX does what it says it will do.
I think all cleaners have their limitations. (Remember Dirty Harry?)
My preference is to use and test non-carcinogenic, bio-degradeable substances.
So if I hear you correctly, you will not require OR state that either Turtle Wax/MMO NOR ARX should have to have independent testing done.
I would like to see it happen, but the costs are so high it ain't gonna happen.
