Car has just under 19K miles on it but it had to have sat for while before we got it. It is a 2011 model but the voice on the Uconnect sounded like an elderly lady. Anyways, we would get a shake in the pedal when braking from higher speeds so I ordered a set of Centric 301 series ceramics from Amazon (love my Prime) and nabbed a set of rotors from Advance using a coupon code of course. I pulled the wheels (must be the first time ever as I had to boot the tire pretty hard several times with my foot to get it to come off the hub. The rotors were still like new (thank goodness, no abundant rusting) so I returned those. When I pulled the caliper (tough too) to inspect the pads I found that they were really worn down to less than 25% life left and the groove cut in the middle of the friction surface was packed full of crud. The new Centric pads had much larger friction area and an angle cut groove in them. I cleaned up the hardware and greased the slide area and put in the new Centric pads and reassembled being sure to put some anti-seize between the lug area. Brakes like new now and no vibration or noise at all. Sweet. Brake job cost me $18.68 for set of new ceramic pads. Gotta love that. The Centric box did say MADE IN CHINA on it
http://www.centricparts.com/products/premium-brake-pads
