p.t. barnum promo
You left off the html after products
This one is amazing
Ecozoil Engine Treatment (ECX72) is formulated from organic-based oil, specifically to suit current gasoline and diesel engines. It contains high grade carrier lubricants, blended with the nano-particle Polytetrafluoroethylene (PTFE), anti-wear, anti-friction and anti-oxidant additives.
How Does ECX72 Seal and Protect Your Engine Against Friction and Wear?
1.
ECX72 is formulated with the nano-particle PTFE. PTFE is less than 1 micron in size and has the lowest co-efficiency of friction known to science. When ECX72 is added to engine oils, the PTFE particle will bond mechanically under pressure when the engine is in operation.
The PTFE compound will automatically "coat" moving parts in engines, and thus, protecting it against friction and wear. When the surface or moving parts are "coated", it is smooth and this will result in ultra low friction between moving metal contact surfaces.
2.
ECX72 has a special additive to recondition oil seals in the engine. After some time, oil seals will deteriorate/harden and it's sealing efficiency will drop. The special seal conditioning additive in ECX72 will "rubberize" the oil seals and increase their sealing efficiency once again. This will automatically stop and prevent oil leaks from engines.
3.
ECX72 has a special metal conditioning additive to recondition metal parts that has worned out. Together with the PTFE nano-particle, the metal conditioning additive will restore the compression efficiency of the combustion chamber by filling in the "nooks and crannies" of it's chamber walls. This will prevent pressure leaks from the compression chamber, increasing combustion efficiency, thus helping to save fuel.
4.
Together with all it's additives, ECX72 will significantly lower engine temperatures, preventing engine oil from oxidizing, thus prolonging the integrity of the lubricating oil. It is proven that adding ECX72 to conventional engine lubricants will extend engine oil change intervals by a minimum of one cycle.
"ECX72 Helps Extend Oil Change Intervals by a
Minimum of ONE Cycle and Enhances the Lubricating
Quality of All Engine Oil Types!"
Benefits:
- Reduce Friction.
- Reduce Wear rate.
- Reduce Temperature.
- Reduce Engine Noise.
- Reduce Consumption.
- Reduce Maintenance Cost.
- Reduce Breakdown Time.
- Prevent Engine Seizure.
- Increase Engine Power.
- Reduce Cold Start-Up Damage.
- Extended Engine Life
- Saves fuel
ECX72 is fully compatible with all mineral based and synthetic based oil.
Directions of Use:
- Add 1 bottle of 240ml ECX72 for cars during each lube oil change.
- For other capacity engines, use 5% of ECX72.
- Use ECX72 every 10,000 km oil change.
Packaging:
ECX72 is available in 240ml bottles.
