Prob worth trying ethanol free fuel
Not sure you can get ethanol free fuel in Canada. And if it's available at all, it would be premium which would be pretty expensive for a vehicle that doesn't require it.Prob worth trying ethanol free fuel
dad's old Ford Aerostars( had 6 or so over the years as company cars) in real cold some were okay, one or two would roast the front seats, but behind that not so much.... a couple ice fishing trips to a lake 45 min or so away... when he got home, the fish, in the bucket right behind his seat, were still frozen solid...Our Grand Caravan is capable of getting uncomfortably hot very quickly even at 0F or colder.
Yeah, not that. Simply it takes time to warm up coolant and to get ANY heat.The sienna has a massive interior volume to heat. 100 cubic feet behind the front two seats just takes time to heat up.
The problem there is not volume, but poor engineering.This is also an issue with Honda CRV and the 1.5t engines, they are already cool running and in cold weather (in the 20's or below) if you call for heat, you can watch the temperature gauge drop. They have variable shutters on the radiator, but heating the fairly large cabin in really cold weather with that small engine is a struggle unless you're doing over 60 on the highway.
You should see at -20f when I started Sienna at ski place.Japanese makers and poor engineering? Can such a thing even exist?![]()
I don't know about you, but it sounds like a pinnacle of engineering to me.You should see at -20f when I started Sienna at ski place.
1. Start it with ski boots still on.
2. Turn on steering heater and seat heaters (horrible speed).
3. HVAC On cold before I turned off vehicle.
5. Take boots off, etc. Take kids boots off. Kepp him in jacket and suit, well, bcs. Toyota.
6. Get in after some 10min, and rpms are still above 1,000 and coolant needle is still having clinical death episode.
7. Start driving. LUCKILY usually I would go uphill to go over Loveland Pass to I70. If Loveland Pass closed, than go downhill to get to road to Breckenridge. Well, let me tell you, that is a nightmare bcs. there is no heat, but I have to turn ventilation bcs. fogging windows.
Once it reaches temperature, it stays, but until then, it was game: how to avoid pneumonia.
No, it's actually very efficient.The problem there is not volume, but poor engineering.
What are you talking about? Nobody here compares the Sienna to some old, iron v8.No, it's actually very efficient.
The reasons are a combination of at least a couple of factors:
-all aluminum engines
-lightweight materials (engines, bodies etc.)
Back in the old days vehicles had cast iron blocks that once up to temp, would create tremendous, consistant heat.
Add to that metal oil pans, valve covers etc. all contributed to making a vehicle a heavy, gas guzzling stove on wheels.
So despite newer vehicles not creating as much heat, they are actually far more efficient than before.
I absolutely do not have those issues with my VW or BMW. Actually Honda Pilot is also not bad.No, it's actually very efficient.
I have a remote on the VW Atlas, but the heating is so efficient, and the engine warms up so fast that I rarely use it. I hate idling vehicles.I don't know about you, but it sounds like a pinnacle of engineering to me.
As many faults as my Grand Caravan has, all I have to do to warm it up is double tap the remote start button and the heated steering wheel and driver seat, as well as all defrost functions will turn on automatically for me. The HVAC will not turn the fans on until the coolant reaches I think 100F or so. I wish I could program the passenger heated seats to turn on as well, but it is what it is. The seats warm up pretty quickly anyways, so it's not a big deal.
In 10 minutes of idling the interior is usually warm enough to not fog up the windows and be all bundled up. It works equally well in 100F weather when it comes to cooling the cabin off.
The heat on the few rental, late model Jettas I had was terrible.I absolutely do not have those issues with my VW or BMW. Actually Honda Pilot is also not bad.
VW is up in heat in 2-3min, the same as BMW. Honda needs bit more time, but nothing dramatic.
VW EA888 engines have integrated exhaust manifold. They literally need 2 miles to get to the coolant operating temperature in extreme cold. That is if I keep HVAC on cold. Maybe 3-4 miles if I turn the heat to max once the needle starts to move. Not sure about renatl Jetta's and issues. I drove some Jetta's with 2.5, and definitely did not have that issue.The heat on the few rental, late model Jettas I had was terrible.
I had to beat them like a red-headed stepchild just to get a trickle of heat.
I admit, a BMW of any vintage is far more substantial, hence the effortless heat.
I attribute that to being RWD biased and possibly from being heavier?
That doesn’t explain why other vehicles with similar construction don’t have the same problems with heat the Sienna does. Our Grand Caravan with its all aluminum v6 gets heat faster than my iron block HEMI does in the truck. I know the truck takes 4 miles of gentle driving to go from a 12 hour 0F or colder cold soak while parked outside to “I need to turn down the heat before I burn my hands.”No, it's actually very efficient.
Very common, especially in cold weather.
Growing up, my family always had 4 cyl Volvo wagons. Some with auto, most stick.
Regardless, anytime of year that little naturally aspirated 4 was always roaring away, struggling to accelerate.
As a result, fuel consumption was always mediocre at best.
Over on the Volvo forums, the latest non-EV SPA vehicles are all equipped with a 4 cyl engine.
Owners are always disappointed at the consumption, appaled they consume as much as larger displacement engines.
Adding insult to injury, they also require premium fuel.
