Oversized Filter for 03 Honda Odyssey
Republic of Texas
Currently running the standard sized Fram X2 filter with Motorcraft 5W20. I plan to switch to Mobil 1 0W20 at next oil change and would like to put an oversized filter on the car at the same time. Is there an oversized M1 or Fram X2 available (3.5ltr V6)?
Thank you ... JHH
PS ... I only found info on the Prelude and Civic when using the search feature.
The Wix #51344 would be a good filter to use.
The Wix #51334 will work but has less filter media.
Thanks.
Here's some info I gathered. Hope it helps.
Stock Size '02 Accord V6 ('03 Odyssey V6)
Part Number: 51334
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.194
Outer Diameter Top: 3.252
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Media Area: 134 sq in
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.475 2.173 0.233
SuperTech 2808, Media Area: 80 sq in
Mobil1 M1-104, Media Area: 112 sq in
K&N HP-1004, Media Area: 124 sq in
Pure1 PL14459 - Relief Valve PSI: 12-15, Media Area: 114 sq in
Height: 2.95
Outer Diameter Top: 3.15
Oversized '02 Accord V6
SuperTech 3950 - same height, greater diameter, PSI: 13-19 ?
Mobil M1-105 - " " " " , Media Area: 140 sq in
K&N HP-1005 - " " " " , " "
Bosch 3320 - " " " " , " "
STP S3950 - " " " " , " "
FRAM PH3950 - " " " " , " "
FRAM PH3985 - greater diameter, greater height, large gasket, PSI: 8-11
Pure1 PL24458 (cross ref AC PF1051, Fram PH3807A, Motorcraft FL-799, Napa 1344, Wix 51344, 51568)
Height: 3.94 (same diameter, greater height, Media Area: 198 sq in)
By-Pass Valve Setting-PSI: 12-15
Pure1 PL14619 (cross ref AC PF9, Fram PH3985, Motorcraft FL-306, Napa 1626, Wix 51626)
Height: 3.75
Outer Diameter Top: 3.70
By-Pass Valve Setting-PSI: 8-16
Part Number: 51568 (cross ref PL24458)
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.072
Outer Diameter Top: 3.234
By-Pass Valve Setting-PSI: 16 ***
Media Area: 242 sq in
Gasket Diameters
15345 2.475 2.173 0.148
Part Number: 51344 (cross ref PL24458)
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.069
Outer Diameter Top: 3.242
Media Area: 192 sq in
Gasket Diameters
Attached 2.490 2.200 0.148
Part Number: 51381 (cross ref Fram PH3950, M1-105, etc)
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.141
Outer Diameter Top: 3.660
By-Pass Valve Setting-PSI: 13-19 ***
Media Area: 224 sq in
Gasket Diameters
Attached 2.834 2.462 0.200 *** Leaks on '97 Integra Type R
Part Number: 51626 (cross ref M1-207, HP-2007, PH3985, PL14619)
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.812
Outer Diameter Top: 3.663
Media Area: 215 sq in
Gasket Diameters
*** Works on '03 Accord I4
*** May work on '02 Honda V6
Part Number: 51347
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Outer Diameter Top: 2.921
Media Area: 211 sq in
Gasket Diameters
15597 2.734 2.430 0.226
Originally posted by 427Z06:
[QB]
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.812
Gasket Diameters
FYI, this filter does NOT work on an '03 Accord I4. I tried it for the first time a few weeks ago and it leaked (more like splashed!) despite tightening it down as much as I could. Interestingly, the same filter works fine on a '95 Hyundai Accent. The '95 Accent and '03 Accord both spec the same stock filter size.
timzak,
Good catch. I guess I should of prefaced my post with the caveat that I didn't try all the combinations personally. I just gathered info from various posts and websites.
I would recommend anyone trying anything but the stock filter size to double check anyone's info as we're all human and prone to mistakes, and then to closely monitor any oversized installations for possible leaks.
I apologize if the info I provided lead to any heartaches.
Regarding those filters that appear to fit but have bypass valve pressures that are slightly higher, ie: 12-15 vs the original 8-11. Does this make much difference with regard to engine longevity?
Tim tried the 51626/3985 on my advice since it works great on my 2.7 liter Hyundai V-6. I feel badly about his results, but not nearly as badly as I'd have felt if he hadn't caught the lube barf before his sump emptied.
Actually Ray, I tried the 3985 on my 95 Accent based on your advice and it worked. I made my own decision to try it on the 03 Accord, so I'll remove you from any liability claims.
