Yesterday i took the heads off my Capri's engine to take them to have hardened exhaust valve seats fitted, so i don't have to keep using a lead replacement additive all the time, the car is from ´75, but the original engine blew up on the Autobahn in Germany in 1991, this replacement engine from a ´72 Capri was fitted back then, had about 50k miles, now it's got about 160k miles, and will be 50 this November, this the first time at least to my knowledge it has had its heads off, i'm fairly happy about the overall condition, lots of carbon as expected, as before 2016 it used a lot of oil due to worn out valve stem seals, but the camshaft looks good, and the bores look pretty good too, to my eye.
Beheaded Essex V6 by Lauri Lind, en Flickr
This engine is a British 3.0 Ford Essex V6, not available in US Capris, as you can see one of the oddities of this engine is the Heron combustion chamber design, with flat cylinder heads, and bowl shaped pistons.
Beheaded Essex V6 by Lauri Lind, en FlickrThis engine is a British 3.0 Ford Essex V6, not available in US Capris, as you can see one of the oddities of this engine is the Heron combustion chamber design, with flat cylinder heads, and bowl shaped pistons.
