Hi,
I believe I got started of the wrong foot, so apologies for the many links in my first post and let me try again
I 've been stalking the forum for a while but couldn't find an answer. so here it goes:
I'm living in Belgium and for some reason it is not easy to get your hands here on premium oil brands like Motul and Mobil1. For the past years I have been using oil from a local brand that seems legit (but I am not sure of course).
For some reason, they have a lot of different variaties in synthetic 5w30 oil. I assume it has something to do with the fact that different car manufacturers have specific requirements for oil. But then I also noticed that the viscosities of the different variants are very different in some cases:
some examples:
Variant 1 - 5w30 FullSynth
Variant 2 - 5w30 FullSynth
Variant 3 - 5w30 Fullsynth
Variant 4 - 5w30 Fullsynth
... and there are a bunch more variants that I wont all copy here.
So I was hoping someone could shed some light on why one manufacturer would make such a big range of different oils within the same grade. And which specs should I look out for?
I have 2 cars:
- A 1992 Mazda MX5 that I love and plan on owning for the next 20 years. I tend to drive it aggressively and often rev it between 4000rpm and 6000rpm (no track use though)
- A 2004 Ford Streetka that my wife is using and that we are not really attached to
So here my questions:
- Does it really matter much for old cars which variant of 5w30 I use? (the oil manufacturer website suggests variant 1 for my mx5 and variant 2 for the streetka, I also have a bottle of variant 3 in the garage that my wife wrongly bought a while back)
- How do I compare those variants. What values am I looking for.
Thanks,
Tim
some examples:
Product specifications
API SN/CF
ACEA A3/B4
BMW Longlife-01
GM LL-A-025/LL-B-025
MB 229.3/226.5
Renault RN0700
VW 502.00/505.00
Typical standard analyses
Density at 15 °C, kg/l 0,857 Viscosity -30 °C, mPa.s 5900 Viscosity 40 °C, mm²/s 72,80 Viscosity 100 °C, mm²/s 12,15 Viscosity Index 162 Flash Point COC, °C 228 Pour Point, °C -39 Total Base Number, mgKOH/g 10,3 Acid number, mgKOH/g 2,10 Sulphate Ash, % 1,33 Noack, % 9,5
ACEA A5/B5, A1/B1
API SL/CF
Meets the requirements of:
Ford WSS-M2C913-D
Renault RN0700
Jaguar Land Rover STJLR.03.5003
Density at 15 °C, kg/l 0,855 Viscosity -30 °C, mPa.s 3890 Viscosity 40 °C, mm²/s 54,50 Viscosity 100 °C, mm²/s 9,90 Viscosity Index 170 Flash Point COC, °C 220 Pour Point, °C -39 Total Base Number, mgKOH/g 10,1 Sulphate Ash, % 1,09 Noack, % 12,1
ACEA C3
API SP
Approved under VW 504.00/507.00
BMW Longlife-04
Porsche C30
MB-Approval 229.51
MB 229.31/229.52
Opel OV0401547
Density at 15 °C, kg/l 0,852 Viscosity -30 °C, mPa.s 5980 Viscosity 40 °C, mm²/s 69,80 Viscosity 100 °C, mm²/s 12,30 Viscosity Index 176 Flash Point COC, °C 224 Pour Point, °C -42 Total Base Number, mgKOH/g 8,3 Sulphate Ash, % 0,75 Noack, % 9,6
ACEA C3
API SN, API SN Plus
BMW Longlife-04
MB-Approval 229.51
MB 229.31/229.52
VW 505.00/505.01
Ford M2C917-A
Density at 15 °C, kg/l 0,850 Viscosity -30 °C, mPa.s 6080 Viscosity 40 °C, mm²/s 75,80 Viscosity 100 °C, mm²/s 13,20 Viscosity Index 180 Flash Point COC, °C 220 Pour Point, °C -36 Total Base Number, mgKOH/g 7,0 Sulphate Ash, % 0,75 Noack, % 9,6
I have 2 cars:
Thanks,
Tim
