My question is not old standards vs new standards. Instead, my question is wether oil late in an OCI is somehow better than earlier in the cycle. If wear is not linear on an oil change cycle, then is used oil somehow better than new oil? -at least until TBN is low? If you look at total wear metals for short OCI and total wear for long OCI, on the surface it may look like long OCI has less wear. I assume that some of the wear metals are going out the exhause or through various seals and gaskets, but should we leave well enough alone once the oil is in the engine. Are moderately long OCIs really the way to baby your engine?
