Originally Posted By: 45ACP
Originally Posted By: Clevy
So why the 0w in a summer driven car. Wouldn't a 10w-30 or 10w-40 make more sense. Less viscosity improvers and more actual oil. Sometimes I wonder about
You must not be familiar with the board. 0W is better in ALL situations. Presence of VIIs isnt nearly as big a factor, particularly in today's motor oils. I also used to give adcive exactly like yours of "stick with the 10W it is the most stable."
RL 0W-30, RL 0W-40, and, dare i say it, RP or AMSOIL.
I summon CATERHAM. He gives the best advice on oils, IMHO. And yes, M1 0W-40 is hard to beat, and would do well in the described car. He s[eaks about oil sbased on their merits, and that is to be respected. I like his postings. (He even used a 20W-50 in his Lotus Europa so he can be objective about what would be the best to use where, and why. He also likes his 0W oils no matter the HOT temp, its all about the COLD and STARTUP and then hot doesnt matter as much if HTHS is appropriate.)
M1 AFE 0W-30 is a light 30 and probably would NOT be ideal for this app. Particularly when even M1 5W-30 coul dbe good.. though i like the 0W oils, if i can find them.
I am VERY familiar with this board, you can verify by my join date, and I still refuse to jump on the "the higher the VII of the oil the better". That's not true for every situation and every climate. Up north, with harsh winters...I agree...the higher the VII the better. Not in the south.
In Florida's (southern) heat of summer, I will take a lubricant with no viscosity improver and degraded cold flow performance. Shear stability and lower NOACK volatility are far more important to me in the expensive engine under the hood of my GT500.
All of you touting "lighter at start up" are splitting hairs when the ambient temps are 90*F and the argument is nil.
In fact, charting the viscosity of a true synthetic 10W-30 compared to a petroleum based 5W-30 will yield very similar results down to 32*F. There isn't a large enough gap in viscosity to make a hill of beans difference. It's all in the choice of base stock.
Comparing 10W-30 petroleum to 5W-30 petroleum is another story.
