Oil Weight Question
I did a search for and it was 140 bucks through Revzilla. Motul 300V Synthetic Engine Oil - 4 Liter - RevZilla https://share.google/1rkgaiFJZ1eRvjyLW
Good deal you found it at $23 a qt. More than double Mobil 1 4T 10w40. People will spend their money where they want.
Well, that only tells you how Revzilla rips people off.
Here's the same oil at $89 for 4L / 4.2 qt / 134 oz. with free shipping. Which is 67 cents per ounce for pure racing oil.
https://www.amazon.com/MOTUL-300V-10W40-SYNESTR
There is nothing racing about Mobil 1 10W-40 4T, except the label marketing. So don't expect their prices to be even close.
I have a 2025 Honda CRF300L Rally. I just had my Suspension done and they changed the oil for me. It’s a big off-road shop and a Beta and Gas Gas Dealer. I only have about 340 miles on it as I’ve only done fairly short rides. Planning a longer trip that would take me over the 600 mile initial break in, so did it now. This model typically uses 10w-30. They put in Liqui Moly 10w-50 4T Synthetic. Is that going to cause a major issue or is that a good choice?
Excellent choice.
What's the basis/background that the Mobil has nothing racing about it, other than name? What about Motul has a better claim to that from what you're saying?
I would suspect you have analysis to show common metrics were Motul outperforms Mobil 1 10w40 4T? I have posted analysis for Mobil 1, I can't recall if you have posted for your use of Motul?
I cannot tell which one will outperform, it depends on the bike. I'm just reading what the PDS says and also everyone around me uses it in high performance bikes, including track use. I don't have a high performance bike to use this oil.
I can tell you without any analysis that this oil is much better that's why is double the price of the Mobil 1 10W-40. If it's too much money for you that's a different thing but it doesn't mean that the Mobil is better oil.
https://www.motul.com/en-US/products/12800?id=12800&product=MOTUL+300V+ROAD+RACING+10W40
Motul 300V Factory Line 10W-40 PDS
https://azupim01.motul.com/media/motulData/DO/base/300v_rr_10w-40_en_de_motul_12800_20240614.pdf
4T racing motor oil developed for factory and high-performance stock motorcycles.
- Increased power for ultimate engine response and acceleration.
- Ester Core® technology for maximum adherence of the oil film enhancing reliability.
API / JASO: above latest existing standards.
Applications: Motorcycle, ATV / UTV / SxS, Personal Watercraft.
I'm not making any inferences to whether it's too much money for me. When I say it's ridiculously priced, that's a fact.
You cannot tell it's a better oil because it's double priced. Provide data to show metrics of additive package, viscosity, TBN over 5,000 mile ocis, unless there are any manufacturer's recommendations for oil change intervals.
It's not ridiculously priced. Full synthetic oils are between $15 and $20 a quart anyway. And that one is most likely shipped from France.
I can only try it in my 2-stroke bike but probably in several years because currently I have Valvoline and Mobil 1 oils. If you have 4-stroke bikes and you never tried it it's on you.
Valvoline full synthetic 10W-40 is $9.75 per quart on Amazon right now.
Price just recently went up, probably due to the base oil shortage issue.
4 seasons (5 races per season) I run on a TT-F3 Japan rules full kit bike Motul 3000 10/40 mineral
the bike on development was blood from stone especially on compression / crankshaft , and limiter, and etc etc
we just change clutch discs, brake pads, tires and suspension service, spark plugs and oil/oil filter
on engine just valve adjustments on all this seasons (no gearbox issues, no piston problems, con rods…)
the biggest improvement on that old 400s was that comes from factory with oil cooler beneath water cooler, and we just add wings from pvc that surround the water & oil cooler to pressurize the air on the fins.
oil temps was monitored better from the stock form of the bike on city driving.
Bitog is a contradiction machine.
“Use the weight Honda recommends, they know what they’re doing”, then in the same sentence “change it every 1-2k miles”, when Honda recommends something like 7-8k miles. Oops, apparently Honda doesn’t know what they’re doing 😆
Personally I would not run a Xw30 oil in a motorcycle with a shared sump, it’s Xw40 or above for me.
Yeah, lol. Run the weight they recommend, to change it four times as frequently as they recommend, haha.
I'm not saying I have more experience than others, however I have experience and I've learned from my experience not just repeating the experience of others.
I have run ester based oils, 40-50% content. I observed zero difference between those and other quality synthetic base oils.
The "to ester or not to ester" question is a moot point in a street bike. Synthetic, yes, in my opinion but the syn base oil makeup based on experience isn't worth the debate. My caveat is unless the oil proves to be less than satisfactory with retaining viscosity which is one of my main criteria.
When a rider wants to run the same oil riders that push their bikes really hard on the track use, companies will make sure they take the money.
That maxima proplus is basically the same price as the valvoline, but boutique oil gives me good feels especially when it says ester. It must be better if bitog calls it boutique AND ester on the labels, right??????1???1?
I have not, however two-stroke oil performance and satisfaction doesn't relate to four stroke oil with respect to what they are designed for. Although I'm sure the Motul two stroke oil works fine.
To be clear, Motul is a very good oil. However I won't be trying it as I have plenty of stock of other oils including high ester content Redline.
With that said, Redline didn't do anything better or worse than non-ester synthetic oils over a 5000 MI oci. Kind of what I suspect would be the outcome with Motul if I ever did use it.
