Oil Weight Question
Would it be ok do you think to leave it in for my trip then switch it out for a 10w-40 around 1k miles. Thinking the Motul 7100?
nothing special on that oil, I use it a couple of times and is just marketing.
a group III oil overpriced with nothing more.
Better oils IPONE Shogun (PAO 50% at least) , Motul 300V Factory Line (PAO 25% at least), Redline (I test 10W30 and 10W40, PAO at least 50%) , Motorex oils also good ones.
the suggestion guys refer here Mobil1 Racing 10W40 (unfortunately not available on Greece, only the 15W50 viscosity) is very optimal for the price.
I suggest also to change the AFR because some people refer that runs too lean of gas.
The piston in photo is with ECU remap and Penrite full synthetic.
So, the engine blew up because the stock ECU runs lean from the factory or because it was improperly remapped? In either case the oil brand doesn't matter.
I highly doubt the 1-st scenario.
I highly doubt the 1-st one.
The guy says ECU remapped.
one option that maybe cause the engine blow up should be bad air filter and extensive dirt comes in.
I see it many times with my eyes on WR450F/YZ450F here in Greece friends run.
Or the remapped ECU was wrong AFR
^^^This^^^ AFR was way lean, IMO. Piston in the pic looks melted or pre-ignition/detonation or all of the above. That isn't wear and tear from dirt getting in the engine, IMO. If anything, the engine runs rich when the air filter gets clogged.
So, the bikes' ECU don't run lean from factory. There are guys who mess up with their AFR and blow up their engines.
It's not dirty filters or debris, as already mentioned above.
The ECU from factory not only run too lean, actually need someone to slap HONDA on eye with hand… and rest companies.
Euro5/Euro5+ emissions and all that stuff only problems brings
10W40 for dirt (not for city driving) with HTHS 4.0+for me is the minimum, on water cooled engine.
from the other Honda suggest 10W30 on XR650L… if oil become 20W after some miles doesn’t matter, Honda add her cherry on top for the ecological benefits.
Need somehow to sell also engine parts for repairs.
