Originally Posted By: HTSS_TR
Originally Posted By: vintageant
tmorris1 - don't just refute! More explanation please!
How many passenger cars have oil temp gauges?
My old A4 had an oil temp gauge. It would never go above 210F, even during spirited driving. In normal driving it would sit around 180-190F.
Our current Q5 displays oil temp. It's typically somewhere around 190-200F.
Some Germany cars have oil temp gauge but most Japanese and Korean cars don't have it. I wish my S2000 has oil temp gauge, so that I may be able to customize oil thickness by mixing M1 0W40 with 0W20.
Currently oil is 60% 0W40 and 40% 0W20 to make HTHS around 3.3 vs 3.0-3.1 of M1 10W30. The reason is the engine is mostly operate around 4.5-5.0k RPM.
If oil temp is below 200-210F after 20-30 minutes of 5k RPM I would reduce 0W40 a little to 40% and increase 0W20 to 60%.
That whole concept drives me bonkers
I'd just run straight M1 0w-40, particularly given the engine also specs 5w-40. I fail the see the logic in trying to "fine tune" the HTHS whiles diluting an already excellent product. Not that they are not both excellent products, they are, but they are not all that similar other than both being products of XOM.
Yes, Honda recommends 5W40 if an S2000 is operated with ambient temperature below 0F, therefore by default 5W40 can be used for warmer temperature.
All Mobil 1 grade are very good, 0W40 are excellent by any standard. M1 0W20 is very good and EP 0W20 is excellent with higher PAO contain than many 0W20. Mixing M1 0W20(especially EP) with 0W40 should yield a very good oil at slightly higher HTHS than M1 10W30.
The S2000 engine is running well with the mix, no worse than straight M1 10W30.
I also running similar mix in E430 and the engine is running very well too.
