wwillson
Staff member
- Messages
- 3,738
- Location
- Naperville, IL
Does anyone know if there is a relationship between oil temperature and the ability of that oil to hold insolubles in suspension?
Blackstone says that 0.7% is the safe limit for insolubles in a gasoline engine. It's a given that hot liquids are more soluble that cold liquids. Could it be possible that the "safe" insolubles limit in the cold of winter might be lower than in the heat of summer? Wouldn't it make sense that when oil cools down to an overnight low of say 0 degrees that some of the suspended insolubles might settle out of the oil? Conversely, wouldn't it make sense that suspended insolubles might not settle out durning the summer with an overnight low of say 70 degrees?
If my hypothesis is correct wouldn't it then stand to reason that the limit for wintertime insolubles would be lower than summertime insolubles?
Thanks,
Wayne
