Originally Posted by VeryNoisyPoet
Originally Posted by dogememe
The oil pressure gauge is fake. The oil pressure switch is just that - a switch, not a sensor. If you have any pressure at all, the PCM generates an oil pressure # based on temperature and RPM... Yes, even the oil pressure PID from an OBD2 scantool is fake. If the switch is defective or there really is no oil pressure the gauge just goes to 0.
Useful info to have, and even worse than I thought. Engine could have critically low pressure even as the gauge happily shows solid pressure, AND the gauge moves as if it were actually hooked to a pressure transducer to fool the user into thinking it's a functional instrument.
It irks me that manufacturers do this type of thing. Pressure transducers are cheap, and they already put effort into designing a gauge cluster with an oil pressure dial. Why not make a useful gauge instead of a mechanical idiot light?!
It makes a lot of sense actually. The average car owner doesn't understand the oil pressure gauge. Slight variances between temperature or something might send them to the dealer with a complaint about the oil pressure.
It's worth noting the TB/Envoy/other vehicles in the platform with the V8 5.3 have real oil pressure gauge... But all 4.2s have the dummy gauges.
