Oil Recommendations
Michigan
I am seeking oil recommendations from all of you folks more knowledgeable than I. I am driving a 2011 Jeep JK sport. My owners manual recommends 5w-20 SAE, API, MS6395. I live in Michigan and only drive the vehicle on weekends for pleasure mostly. I don't often take long trips they are usually short and I don't have any mechanical issues with the vehicle. The vehicle has about 65 thousand miles. I prefer a synthetic oil and to change the oil every 4-6 thousand miles.
What do you recommend??
Buzzy
Is the Pentastar engine in your JEEP ?
My buddy has a JK that has the Pentastar and it has used a .5-1qt within 4500mi OCI's since new, with AMSOIL Signature Series 0w30, Mobil 1 (against my will), PP and JEEP factory fill. We switched him over to T6 0-40 and the consumption has been GONE for 24k mi now.
If you wheel it I would go for a HDEO, if not it seems that GC would work well.
I find myself in the thin crowd. With no current issues, I don't think I would go with a thicker oil.
I would personally do one of two things:
1) Do exactly as you have been doing the last 65k, it seems to be working
2) Use a Walmart available MS6395 0W20, like Mobil 1 Advanced Fuel Economy or Pennzoil Platinum (I'm sure there are more)
2011 would be a 3.8 and I would use Pennzoil Conventional 5w30.
In my '14 3.6 Pentastar I use Pennzoil Conventional 5w20 every 8k with no issues.
Buzzy
Do what the manual says.
I don't know why people are saying use a 30 without even knowing if vehicle has consumption issue.
I would also stick with manual rec. of 5w20 (PR 0w20 since short trips). Personally I would go with Quaker State Ultimate Durability, PP, Mobil 1 0W or 5w20. Mobil 1 isn't MS6395 but doesn't matter IMO.
You could probably be fine using a good Dino but with short trips and MI weather I'd use a syn as well. If you have consumption issues going up a grade might be useful however.
another interesting consideration is "off road use", even trail riding is enough for me to bump up in viscosity.
I couldn't imagine having a jeep and only use it on road......
You should buy 6 quarts of whatever synthetic 5w-20 is on sale. You didn't mention annual mileage and any consumption issues. I doubt you will notice any difference between Mobil, Pennzoil etc.
