Oil recommendation for a 1991 Lexus LS400?
Finland
Greetings and salutations.
I'm supposed to pick up the Lexus this weekend and in order to get to the stores on Saturday to pick the oil I'm facing the old dilemma ie. what oil to use.
The car has 120k miles on the clock and has full service history. At this point I do not unfortunately have a slightest idea of what oil has been used but I just wish to treat her well and keep her for a long time.
My use will be mix of cruising in town, commuting and touring perhaps 10k miles per year - my daily driver is the Corolla in signature.
As I have mentioned earlier the 5w30 is somewhat odd viscosity over here and the availability is limited and sometimes quite expensive, such as Castrol Edge.
This is what the manual says:
These are the 5w30 oils that seem to be easy to get locally:
Valvoline MaxLife 5w30: WSS-M2C913-A WSS-M2C913-B WSS-M2C913-C, API SJ, ACEA A1-02/A5-02/B1-02
Ford Formula F 5w30: WSS-M2C913-B, WSS-M2C913-C, API SL, ILSAC GF-3, ACEA A1/B1
GM Longlife: ACEA A3/B4 ja C3, API SM/CF, GM-LL-A-025, GM-LL-B-025, BMW LL-04, MB 229.51
Mobil Super 3000 X1 5w30: ACEA A5/B5, API SL, Ford WSS-M2C913-C, Ford WSS-M2C913-B, Ford WSS-M2C913-A
Then there's of course Mobil 1 0W-40 and Shell Helix Ultra 5W-40 and other oils as well.
Of these 5w30 oils above what would you recommend or does it matter ie. would each and every one suit the 1UZ-FE just fine?
I would get an oil that has a high cleaning ability for the first few changes to flush any old [censored] out. Then switch to an oil of my choice.
That engine will be the last thing to ever wear out on that car. Max life would be great, but i think that engine will run forever on just about anything.
The cost is not the essential factor here but Ford and GM oils - and especially the GM oil - are very, very affordable. Shell Helix Ultra 5W-40 about the same as Ford oil pricewise.
Originally Posted By: Boss302fan
PP or even plain jane Pennzoil conventional would be good choices.
Pennzoil products are not easy to get here but Shell products are on just about every market shelf.
I have this same car... Mobil 1 5w30 until just recently, and now switched to Mobil 1 5w30 HM
Fantastic car by the way.
Thanks guys, much appreciate your comments.
Any idea if the GM oil is an OK product?
Here's a thread on that very same oil:
https://bobistheoilguy.com/forums/threads/who-makes-gm-genuine-dexos-2-motor-oil.172519/
One of the posts says that GM's suppliers are Wolf Oils from Belgium or Total.
Here in the US I think we have a lot of choices because there's a fairly healthy do-it-yourself market. I was told that in European countries, most servicing of vehicles was required to be performed by licensed mechanics.
What would be least expensive?
I'd say that the GM Dexos 2 oil would be a good choice. It meets A3/B4, so it would work well, although it would be a higher HTHS oil than what Toyota originally recommended.
Certainly won't hurt the engine, but probably thicker than needed.
Maxlife might be a better choice. API SJ is a more recent spec than existed when this car was new, so there should be no problems with that. Maxlife has worked well for me in a few applications.
I don't think that it'll hold up for 10K miles, though, while the GM Dexos 2 oil probably will.
You have a great engine in a great car. I doubt that any S-class or 7 series of the same vintage would hold up to time and miles any better if as well.
What an unplesant surprise this car must have been to DB and BMW when it was introduced.
People from both makers tried to trash-talk this upmarket Toyota, but it became solidly popular among high-end buyers, at least here in the US.
It may not have been autobahn bred, but it still runs like a fast and comfortable train.
I would also pick up a new pcv valve (should not be expensive), and whatever your favorite 5w30 syn is on sale. Actually if 5w30 isn't available, whatever is your common oil in your location will be fine.
(Owned '90 LS400 from 1997-2009)
The main common problems of this car will be:
-the power steering system will develop an issue where a particular air valve does not close properly, and fluid will be sucked into the vacuum system and burned in the intake. You can plug and cap off that part of the PowerSteering solution to fix it; or just deal with it by just topping off the fluid. (Uses Dex II or higher compatible ATF).
This may cause contamination of a lot of systems if this happens for a long time.
-the AC/Radio LCD display panels will likely go out.
-the suspension is likely not very good anymore and will need replacement.
You can search on lexus forums for these specific issues if you need.
Went to see the car today. Was pleasantly surprised of it's good condition and as we agreed on the price I'm now a happy camper.
According to service manual she has been fed with 5/10W-40 oils since new - European Lexus manual shows 40 as well as 50 grades in addition to 5/10W-30 oils. My Corolla gets Shell Helix Ultra 5W-40 so that's what we put in now. I may consider Mobil 1 0W-40 in the future but we'll see.
Just three things to do:
- OD light blinks in the gauges -> could be a corroded connection or sticky/bad solenoid
- engine runs at 66 degrees Celsius -> thermostat probably stuck open a bit
- small LCD display up in the center console is very dark -> need to get new one
The ride is phenomenal!
Shell Helix Ultra 5W-40 is great oil. Out of curiosity, can you get Shell Helix Ultra AS 0W-30?
After you replace the thermostat, you might want to check the condition of the coolant. If needed, flush out thoroughly and go with Toyota Super Long Life coolant (pink stuff).
Not at least locally - not sure if they import it.
Roger on the coolant. Winter is coming and need to get that thing in order as well.
Any light A5/B5 0W/5w30 (not A3/B4) would be the oil grade to use and that would apply to your Corolla as well.
A 0W/5W-40 would be considerably heavier than necessary particularly for winter use.
