I have a 65 GTO and I am concerned about oil selection since they have reduced the ZDDP in normal oil. So I have done a lot of research on the subject and what I have basically found out is the ZDDP level depends on the engine and its use. The general consensus is somewhere between 1200 to 1600 PPM Zinc for high performance street driven cars with hydraulic flat tappet cams. But that does not narrow it down enough for me so I thought I would ask the experts.
My car is used for street use only with weekend cruises and maybe a cross country Hot Rod Power Tour. It is a muscle car so it will have the occasional stop light flogging but will never see the strip.
My car is a 1965 Pontiac GTO with a 4 speed and 3.36 rear gears. The engine is a 1969 Pontiac 428 bored 30 over (433). It has 10-1 compression with Edelbrock aluminum heads that have been heavily ported with an Edelbrock Performer RPM intake that was ported to match the heads. The carburetor is a 1976 Pontiac Quadrajet 800 CFM that has been tuned for the engine. The cam is a Lunati VooDoo Cam 60903 with a center line of 110, advertised duration 268/276, duration @ 50 227/233, and lift with 1.65 roller rockers of 538/554. The estimated HP will be around 490 and the torque will be around 590. Spring pressure will be between 115-120 for seat load and 319-336 open load with a spring rate around 400. I still haven't decided on the springs, this is what is recommended for the cam.
I would like to use something that is complete, designed for engines that are not started everyday, and requires no additional additives. I have done research on the Lucas Muscle Car Oil with 2100 PPM Zinc, Champion Classic & Muscle Synthetic Blend with 1627 PPM Zinc, Amsoil Z Rod Oil with 1440 PPM Zinc, and Comp Cams Muscle Car Oil with 1300 PPM Zinc. Would any of these be a good choice for my car or would you recommend something else?
Thank you for your time and advise,
Dale
Dale
