cwlesq
Thread starter
Thanks for the all of the info
cwlesq said:Thanks for the all of the info
Definitely make sure the timing belt/water pump service was done on the Lexus. The LS400 was the top of the line Lexus that was built to beat every other luxury car made around the world. It is an extremely reliable over built car. They did many special things to the LS400. I read that they even weighed each piston that went into each LS400 motor and all the pistons had to weigh exactly the same weight before the motor was assembled. The LS400 I bought with 293,000 miles on it ran like new. It is a special car. I just want you to know that you can get many more miles out of that Lexus if you properly maintenance that car. That car is worth it.
Since many older Lexus cars have automatic transmission issues around 240 thousand miles I will tell you what my friend who owns a transmission shop told me. I asked him when he changes the trans fluid in his personal cars. He said he services the automatic transmissions in his own cars every 15 thousand miles due to transmission fluid gets very worn out at around 30,000 miles. This depends on the vehicle and how hot you actually get the transmission fluid. A 4x4 could burn transmission fluid up and wear it out withing 500 miles by getting the trans fluid too hot. He does not recommend a power flush due to that can force small particles into the transmission on an older car and cause serious shifting problems. He recommends just the regular trans service fluid and filter change which only gets out 1/2 of the old trans fluid. This is why he changes his every 15 thousand miles, because he is only getting 1/2 of the old fluid out of the car every time he does it. He said transmissions last an extremely long time servicing them this way when the car is taken care of.
I have been servicing the automatic trans in my 2003 Cavalier this way for the past two years because the car has 170,000 plus miles on it. It runs like new and I do not want the trans to go out on me since I plan on driving it well over 200,000 miles.
That is solid advise. Thanks.
