Originally Posted By: gtx510
1. Maybe a tribilogist could chime in but in my reading VII's are more related to temporary shear.
http://books.google.com/books?id=gbBQ2pR...num=1&ct=result
http://books.google.com/books?id=cwWgbmL...esult#PPA345,M1
2. Aren't low viscosity oils w/ high HTHS values popular in Nascar and other V8 engines where they are using a high volume oil pump?
There's a high volume (Cosworth?) pump for the sube, but I don't think any model comes with it stock.
3. With Subaru rec'd 5W-40 and 5w-50 oils for warm climates, and all the detonation and spun bearing issues that the STI engine has, a thinner oil would be the last thing I'd use.
In the UOA's that I've looked at GC's used viscosity is still thicker than ACD's new viscosity.
And you still haven't addressed the issue of too much oil pressure during cold starts....
4. ACD is $31.05/gal, $27.95/gal w/ the 10% discount.
That's $6.99/qt PLUS shipping.
Not any cheaper that GC, especially not if Syntec is on sale.
And you can get GC off-the-shelf at almost any Autozone.
1. That's what I said. Are you implying temporary shear is not a problem in a high performance car?
2. Are you implying a high volume pump is required to run a 30wt? I think a simple oil pressure guage would say differently.
3. Too much oil pressure during cold starts? What's funny is the ACD is thinner at 40c. This is the same paragraph where you recommend a 5w-50 which in reality likely has a higher starting viscosity in any normal ambient temp.
4. So you're paying about the same for inferior GC. What's the hang up about shipping? Is it impossible to plan your oil change 2-3 days in advance? Order on a Monday and it's there in plenty of time for a weekend oil change and delivered to your door.
I'm a fan of thicker oils in performance cars but I don't understand the obsession with 0w oils in mild climates. If it were my car it would have a 15w-40.
