Update:
Over the weekend I tried a couple of different filters on my 350Z to see if the oil pressures would move around.
Here is what I tested:
1. Bosch filter
2. STP Filter
3. FRAM
The STP and FRAM filter were both stock size (little baby filters) and the Bosch was oversized.
All filters performed nearly identical for oil pressures within say 5psi of each other. This then rules out that the increased oil pressure is from the filter itself.
I then tested the oil pressure with the BOSCH and STP filters versus ambient outside air temp:
1. Cold mornings: 40-50F -- oil pressure increased by 10spi (compared to hot days) even when the engine was fully hot.
2. Hot days were temp outside was 80-90F oil pressure reduced significantly.
This seems to indicate that the outside air temps have large effect on oil pressure whereas the filters have little effect.
So at this point I am happy running the Bosch filter. The increased oil pressure seems to be due to the oil itself as reported by several other people here and on Z car forums. The engine seems to like the synthetic oil as I get better gas mileage with it, but I have not done any used oil analysis as of yet.
1. Bosch filter
2. STP Filter
3. FRAM
