Quote:
Quote:
If an old engine is showing low oil pressure what is the better solution? is it to replace/repair the pump or put in thicker oil?
I've wondered the same thing. I've read Dr. Haas's Motor Oil 101 several times now. Thanks Doc. That has been one of the most interesting and informative things I've read on motor oil. I learned a lot from that. I've got an old '84 diesel Rabbit where the oil pressure is not ideal. It is OK when the RPMs are up and the oil is warm. However, when the oil is up to temp and the engine is idling, my pressure is low. My plans are to replace my oil pump with a higher volume pump, and then see if I can go to a lower viscosity oil (currently 15w-40 HDEO -- would like to then try a 5w-30 HDEO). I personally would only move to a higher viscosity oil if I new that the oil pump couldn't be improved upon and I still had low pressure.
-Bryan
