Why not buy the proper product?Hi Friends.
For the outer surfaces of car where it is exposed to dirt, stones and water splashes regularly, rust prevention may require a little more extensive work,
But most of in my case, there are small areas inside (such as door hinge, footwell, at some cable connectors) that i see sign of rust and want to stop the progress.
I used to think motor oil could do the job, but some people stated that motor oils contain some acidic content which may promote the rust.
Can you please make suggestions about what type of oil or grease can i use as an easy solution?
Mineral Oil or Vegetable oil or Lithium grease ?
I prefer oily stuffs instead of paint, because oil is easy to apply everywhere while paint not. Please do not suggest me things that i may buy from e-bay or amazon as i am outside the US and need home-made things![]()
Regards.
For areas that get a lot of road spray NH Coatings sells (among other products) a thick product product that you brush on.
