Oil On Ignition Coil/Spark Plug
The part# for oe Acura/Honda valve cover gasket is: Honda/Acura 12341-RCA-A01, I have to call dealer and check price. The gasket fit 2004 Honda Accord Ex V6 model and my 2004 Acura MDX
Buy a FelPro set that has the gasket and tube seals in it. Clean and reuse the coils and replace the plugs while you are there.
The fel-pro set is easy to get my hands on locally, All the parts stores in my area have them in stock.
Some Honda engines also have rubber seals at the bottom of the spark plug tubes. Removing the rocker assemblies is necessary to replace those seals. I don't know if this is one of them.
