Went to change oil in son's 1994 olds 3.1 chev motor. I mistakenly took the Boss 15-40 dino HDEO rather than the Boss 0-30 HDEO syn oil. This engine ran great on this 0-30 Boss all winter for an 8K km OCI without oil burned.
I go to his 94 olds manual, they specifically stress no 10-40 or 20-50 weight oil, NOT RECCOMMENDED, they recommend 5-30 or 10-30 onlY.
All my other gassers allow a 40 weight oil above 0F or -18C, this 94 olds is not endorsing 40 weight.
This engine has 203,000 kms or 125,000 miles, runs great and does not burn oil, I dont want to do damage this engine.
Is this HDEO 15-40 okay in a 3.1? Should I drain two litres and add two litres of the 0-30 in a blend? Drain all and fill with the 0-30?
Is there new thinking on heavy 40 weights in these early 90's 3.1 chev engines now so I can keep this oil or should I drain it according to manual's recommendation?
Thanks
Cyprs
Thanks
Cyprs
