Oil gelling
I bought Mobil Delvac 1300 Super HD multigrade engine oil by the drum, to save money. Have a pump mounted on the drum, in a shed. Takes me several years to use it up. I change oil not very regularly, but after a few thousand miles or a year or so. Do not drive a lot. Run this oil in everything, from lawnmower to antique tractor to 1950s truck to modern (20-year-old) Subaru.
Over the last year, I have started to find oil thickened to tar, in more than one vehicle. Made a 50-mile trip in my old truck on Friday, ran fine, good oil pressure all the way, and when I got ready to start home I checked oil and found none on the stick......long story short, crankcase (and oil filter, and oil pump, and every passage was full of what acted like, maybe 20 durometer rubber. I had changed a crankcase full of badly thickened oil out of this truck, replaced oil twice, only a couple of months go, maybe 500 miles. Now that I think of it, I drained badly thickened oil out of a Subaru a few months ago, replaced the oil, ran it a few miles and replaced it again, then the engine seized up a month later. Lost a bearing in a Yanmar tractor last Fall. Same oil in all. The unused oil from the drum looks fine.
I have heard of engine oil gelling under SEVERE service, but I do not operate this equipment any differently than I have for 50 years, and never had this problem before. I am going to take samples to the oil distributor, but expect no light or satisfaction there.
Anyone have relevant ideas or experiences (including maybe a good solvent for the "rubber" that I am going to have to clean out of all the drillings in the truck engine)?
What conditions is this drum stored in? (temps etc?)
IIRC, oil exposed to the elements deteriorates faster than fresh oil from a sealed container.
Which is why I only purchase 5 liter jugs and use them accordingly.
So, you've damaged or ruined at least three engines (truck; Subaru; tractor) and somehow think you've "saved money" using a bulk drum? And your greatest concern is finding a solvent to presumably help dissolve the remnants.
I find this hard to believe, TBH. But I'll play along ...
Send in a VOA of the oil from the drum, and send in some oil for used oil analysis as well.
Post the results in the proper forums here.
Not the first time we’ve had new users post that a specific brand has “siezed their engine” or otherwise had some sort of catastrophic failure.
What are the “drillings” in the engine? Got some pictures?
This is one similar thread from the past, there were others:
1st post.
Bizarre story.
I'm not buying it.
OP, we need some proof of this bizarre occurrence.
C'mon now.
This oil thickening issue has arisen several times with different vehicles, and you didn't realize that the common denominator was the oil?
I think you're messing with us.
Multi grade ? You mean viscosity? That would be the key word for storage jelling, yeah I'll here the music now.
Never ever seen nice straight SAE 30 Jell so?
Grab a sample of the oil in the drum for oil analysis at Blackstone/similar. Surprised you continued to use it after the first occurrence. Is it possible someone thought this was a waste oil/whatever container and dumped something in it based on where the drum was stored? Based on your description I imagine an old shed on a rural property and someone bee-boppin' along looking for a place to dump some old whatever fluid and well here you are. Water ingress into container? Maybe several short interval changes with a basic oil will help remove the gunk. Good luck!
I have given samples both of unused oil from the drum, and the gelled stuff, to the oil dealer, in hope of getting them or their source to get an analysis. Perhaps one or more of you would be so kind as to suggest suitable , maybe even reasonably-priced, analytical labs?
I am not trying to diss the manufacturer of the oil, just giving all the information I have in hope of getting a useful answer.
Storage conditions: seasonally varying ambient temperature, unheated shed.
Nobody dumped anything in the drum.
No sign of gross water contamination, i.e. no milkiness.
By "drillings" I mean engine oil passages/galleries.
I MAY be an idiot, but I do not think I have given good grounds for that assumption, yet.
I am here because I ASSUME that there is a lot of knowledge about oil here. Can anyone definitively tell me that X % water will cause Y types of oil to rapidly polymerize, and suggest a mechanism?
I agree that the occurrence is bizarre. That is why I am looking for help understanding it it. I have better things to do than make up sad stories. I could post a photo of black gel, but I doubt that would have any probative value.
Many thanks to those who have offered information or additional questions.
Water won't polymerize oil. It can do other things but it won't turn it into a 20 Durometer rubber.
Where would this water be coming from anyway?
This kind of a drastic thickening, provided we’re not being trolled here, would really only be caused by contamination. Normal engine operation would not do it to a fairly fresh oil.
Perhaps someone added something to these engines? Bad neighbor, co-worker, ex-wife?
This would be my guess.
I'd just use Blackstone. You can go to their website and order test kits for free.
Perhaps a magnetic anomaly.
That oil is FF in the GM DMax and CAT equipment … It’s rebadged in CAT drums and sent out globally - Made from EHC - but can’t handle some clunkers …
Not buying this …
we had oil turn to thick jello just like the OP described, it was fresh oil for a very expensive deutz diesel engine.
We never got to the bottom of it but it might have been iD10T operator error. They used the same funnel after adding DEF fluid.
Maybe the nitrogen in DEF gelled the oil.
Rust Belt Pete's answer is very interesting, but there is no DEF (urea) anywhere around here. I think sabotage is also unlikely. I asked about water because some posters proposed it, and certainly moisture/humidity could have gotten into the drum as it breathed with temp variation, but the unused oil looks quite clear.
To 4WD, okay if you do not buy my story, can I interest you in a good price on some black jell-0? I guess "FF" means "factory fill". What does EHC mean?
I will look into Blackstone, thanks to TiGeo
