Hi All,
I've been browsing this forum for about a week. Folks - I have to hand it to you, there are some seriously knowledgeable people on this board. Thanks for offering your knowledge up so generously. I'm currently reading the Motor Oil University write-up and I'm seriously impressed.
In the yachting world, a lot of us run small, diesel engines that are essentially and old school agriculture/industrial engine that has been marinized with a fresh/raw water heat exchanger and (sometimes) a raw-water oil cooler. Sometimes they are turbocharged and intercooled in larger boats, but most engines are NA.
Our engines are used much less frequently than a typical marine engine since they are an auxiliary engine. We get from Point A to Point B as much as we can under sail. Sometimes we motor sail, which is essentially reducing the engine to half speed and allowing the sails and engine to work together (usually in a situation where there's minimal wind).
There is a lot of concern in the yachting world about "over-specifying" synthetic oils and high TBN numbers in our little diesels. In our manuals, manufacturers will usually point to some completely outdated/obsolete/retired API spec such as CD - 15W-40 or straight 30W. I believe that's where most of the confusion comes from. A lot of folks point to this article when talking about over-specifying oil. It's kind of a smash hit on forums when talking about oil in the sailing community.
I'm wondering if you guys can shed a little light on what's appropriate to run in our diesels and if the article I linked above has merit.
Thanks.
Thanks.
