Pentosin HP II 5w40 formula change
Martinsburg West Virginia
Hope this is the right place to post, it is both diesel and European, if not please move to the correct area.
Either way, I have a 2006 VW Jetta TDI with the cam eating PD engine, just flipped 250k miles. It has a new cam and lifters in it, done about 13k ago with no issues. I have been using the Pentosin HP II 5w40 oil as it is what Frank06 recommends for his cam packages. I figure that it is safe to assume that is a good choice if he recommends it. Now, I did not get his cam package it is just a regular cam for the BEW engine, mine is a BRM. Used that cam since it is a milder grind and tends to have less issues in the long run. Didn't know how well the engine ran when I bought it so it didn't make sense to go all out not knowing if it even runs okay. It does drive fine and is a great car!
At my most recent oil change I realized that the specs had changed on the bottle of the oil and not sure if it is still a good choice? It seems that it is now rated for VW 511 and only "recommended" for VW 505.01 applications. If my car didn't have the cam eating engine, I wouldn't worry about it too much. But I really do not want to lose a cam and lifters because of the wrong oil choice. Does anyone know if this reduced emissions formula is a bad idea to use? I am including pictures of the back of both bottles below:
I know in the case of the clean diesels they use the emissions friendly oil (VW 507.00 5w30) and it is robust. But that oil really wasn't a great choice for the older TDI engines due to viscosity and altered additive package. So I wonder if this is the same scenario? I know VW 511.00 oils are basically a thicker version of the 508.00 oils which are also meant for emissions more than anything.
