I thought an LS1 motor would have been covered many times, but the search return zero results for 'LS1', maybe my search skills need optimising. I have a Holden Commodore with the LS1 engine. I have the standard mods, exhaust, OTRCAI, mafless tune etc. Just trying to work out if I should swap to a different grade oil.
The manual says SF or SG multigrade oil. It doesn't state viscosity as it refers to attached chart, which I cannot find.
From http://sikls1.v8owners.com.au/index39.html, For optimum fuel economy, use 110w30 SJ GF2 engine oil, if this oil unavailable, use SG,SH or SJ grade engine oil with viscosity of 20W/50
*I assume the 110w30 should say 10w30
I live in Queensland, Australia so the climate is pretty warm and would never see below 0c. The car may be left for a few days at a time, but when it is started it is a 20min drive to town. It's vary rare for the car to see a real long trip. It has 140,000km on it. Suffers the normal LS1 piston slap for a few secs when cold started, and does use some oil between changes. It never gets used at the drags or track, but does get some WOT boy racer work. I tend to do 10,000km oil changes.
From http://www.ls1.com.au/ recommendation I have been running Castrol Edge 10W60 for the past few years. I have been worried it's a bit heavy of an oil for daily duties. I'm thinking of changing to Castrol Edge 5w40, as it is still fully synthetic, a lighter weight for the starts and closer to the factory spec oil. I don't like chopping and changing oils all the time.
Is my idea a good one?
