Originally Posted By: Ducman
I note your comparison of critical engine clearances.
Note the minimum clearances.
I've done the same investigation myself in order to get to the bottom of the matter, and make sense of it my own mind.
Previously I also felt the thin oil requirement for LS series engines, may simply be an internet myth.
With reference to the factory clearance tolerances of the LS2 engines.
I flat out wouldn't like to be running any of the thicker oils in my engine, if I happen to draw the short straw if the clearances in my engine happen to be at the bottom of the tolerance range.
Only to potentially have insufficient oil flow, due to the oil being too thick.
Boundary lubrication is not my idea of an ideal scenario.
The clearance is still above the minimum oil film thickness needed to be hydrodynamic in those journal bearings. The question of thick vs. thin has more to do with the designer's use of the oil film thickness calculation of (viscosity x RPM) / BearingPressure. Lots of discussion on the Stribeck relationship formula for oil film bearing riding. For a bearing to lower the BearingPressure, they would be constructed wider. I wonder how the BMW S65 and GM LS1 V8's bearings compare in width, the wider one being able to use thinner oil.
