Given it's a MasterCraft I expect it's an inboard with a transmission and a prop shaft and prop.I would probably go with an actual Marine 25-40 for that as I suspect you won't be lightly cruising a mastercraft, if not then Mobil 1 15w50 would be decent and Royal Purple has an HPS line of oils that have high ZDDP levels (maybe their 10-40 HPS would be good). My larger concern would be the gimbal bearing and outdrive oil.
