Propflux01
$100 Site Donor 2026
Just curious what OCI are you using with the HPL?Mobil 1 should suffice. I'm running HPL 5W30 in my 24 Mazda 3 turbo.
Why bother with expensive oil like HPL to only go 5K? I'll have 8K this year on HPL and that will include 8 track days.Just curious what OCI are you using with the HPL? I put the HPL in the wife’s 1.6T Kona, and she’s only got about 2500 on it so far. I’m thinking sticking with 5k.
Because I want the best of the best, and that doesn’t necessarily mean I can roll out longer mileage, and just end up with a mediocre burned out oil in the end. I also have warranty concerns to contend with.Why bother with expensive oil like HPL to only go 5K? I'll have 8K this year on HPL and that will include 8 track days.
Marketing tells you that Supertech is not the best for your intended application?Because I want th
So you think HPL is a "mediocre burned out oil" putting more than 5K on it? I can tell you the oil I will remove at the end of this year will not be that.Because I want th
I look at it this way. I get an oil that’s good for 5 k intervals and by the time that 5 k comes around, that oil is spent, and probably starting to cause more oil related funk (breakdown, varnish, etc) because it’s at its end. So now I use the HPL and I run it to, say, 10k. By that 10k, I’ll be in the same place I am with the earlier oil. So I have a couple options. Cheap oil, that works minimally, and I can change it out early, or use the HPL, which I know is better than the cheap oil, and still change it out a bit early, while it’s still at its peak. Hence why I asked earlier what OCI the HPL user is using on his.i also stated I had warranty concerns. I don’t need to try and justify to a dealer I use super quality oil, when all they are gonna do is look at the OCI….So you think HPL is a "mediocre burned out oil" putting more than 5K on it? I can tell you the oil I will remove at the end of this year will not be that.
Nothing in marketing has told me it wouldn’t, or for that matter, that it would.Marketing tells you that Supertech is not the best for your intended application?
Well the certs on the bottle say otherwise.Nothing in marketing has told me it wouldn’t, or for that matter, that it would.
And?Well the certs on the bottle say otherwise.
I think your view of what oils are good for w/r to miles is a bit old-school. Any name-brand OTS oil can easily go 5K with plenty in the bank. HPL would be much more than that. I mean there are users here using HPL products for 20K+ miles and their engines look spotless and used oil analysis show the oil was still ok. 5K is "hold my beer" territory in 2024.I look at it this way. I get an oil that’s good for 5 k intervals and by the time that 5 k comes around, that oil is spent, and probably starting to cause more oil related funk (breakdown, varnish, etc) because it’s at its end. So now I use the HPL and I run it to, say, 10k. By that 10k, I’ll be in the same place I am with the earlier oil. So I have a couple options. Cheap oil, that works minimally, and I can change it out early, or use the HPL, which I know is better than the cheap oil, and still change it out a bit early, while it’s still at its peak. Hence why I asked earlier what OCI the HPL user is using on his.i also stated I had warranty concerns. I don’t need to try and justify to a dealer I use super quality oil, when all they are gonna do is look at the OCI….
Perhaps old school, but I look at the difference in quality. A yugo might get me 5k, but a Mazda will do it much better, reliably, and safely. Especially if I beat on it.I think your view of what oils are good for w/r to miles is a bit old-school. Any name-brand OTS oil can easily go 5K with plenty in the bank. HPL would be much more than that. I mean there are users here using HPL products for 20K+ miles and their engines look spotless and used oil analysis show the oil was still ok. 5K is "hold my beer" territory in 2024.
I still don't see how a top-quality oil like HPL has issues in your mind past 5K, it goes against everything on this site w/r to HPL. whatever floats your boat for sure here, your car but that HPL is more than good for many more miles past 5K.Perhaps old school, but I look at the difference in quality. A yugo might get me 5k, but a Mazda will do it much better, reliably, and safely. Especially if I beat on it.
I’m sure it is. And I was curious enough to ask a person who drove the same vehicle as me what his OCI was, to debate going further .I still don't see how a top-quality oil like HPL has issues in your mind past 5K, it goes against everything on this site w/r to HPL. whatever floats your boat for sure here, your car but that HPL is more than good for many more miles past 5K.
This is BITOG man, you ran a 20 grade so clearly were on the cusp of total engine failure.I had a 2018 Mazda 6 with the same 2.5 NA engine in it. I ran 7500 mile oci with whatever 0W-20 full synthetic I could get at Walmart, and a couple 0w-40 Euro runs at the end. Did so for 80,000 miles and although I have 0 used oil analysis to show, I never saw any difference in oil and the old oil never raised any alarms with me. The SkyActiv engines just don't care what you run in them.
Ohh true. Didn't think of that. Good thing the car was totaled in a wreck in February. The engine didn't get a chance to die on me.This is BITOG man, you ran a 20 grade so clearly were on the cusp of total engine failure.
