Awaiting my 2012 VW Turbo Beetle and want to install a 'sandwich' adaptor to connect 1/8" NPT sensor for oil
temp that would be coming from my after market dash mounted
gauge. None available in the needed 27mm X 1.5 size and also
came to realize the thread is opposite of the usual ones.
Did find a machinist in Australia who is quite experienced
in 'sandwich' adaptors and he agreed to build me one. To help
him I sent an oem filter (VW #06J115403J) and he was curious as
to the reason for this four-spoke ring that also has attached
to it a recessed outer '2 walled' ring? Even the aftermarket
filters for this car have the same set up and they include
Purolator L35895, Wix 57561, and Baldwin's B7452. Have told
him to follow the design exactly so that the 'sandwich' will
sit exactly against the engine as the oem one, and sit against
the base of the filter also in the same way. This filter is
used by many other VW & Audi models and I wonder why it was
constructed in the way it was, especially the part of it that measures a huge 27mm in the thread which no other 'sandwich'
adaptors are available in?
