Hi Team
I've conducted some testing on my car to see the different pressure drops across different filters.
The results? - It was a fizz.
When the filters are NEW, they all represent zero restriction to oil flow and pressure.
The *actual* loss shown on the graphs will be because of the change of oil flow direction, not the media itself.
Conclusion - run whatever filter you want that has reliable construction and good efficiency rates.
The filter will only become a restriction once it starts to get filled with debris. A larger filter should technically be able to hold more foreign matter before pressure drop occurs.
Oil System overview and schematic showing sensor locations:
Wix 51515XP versus Mitsubishi OEM MD356000.
The Filter filter is physically around twice the size of the Mitsi oil filter.
Just to confirm the data above, I found the smallest non-bypass filter I could.
Ryco Z442.
And the results?
The same....
Cold startup is the same.
~10-20kpa pressure differential across the oil filter.
From the testing i've done - the only reason the bypass is opening is when the filter is blocked.
If it's opening - it needs to be changed.
Enjoy!
Ryco Z442.
And the results?
The same....
Enjoy!
