Originally posted by Digital2k2:
Hey everyone, I'm curious as to what oil filter you'd use on a 2004 v6 silverado that sees mostly highway mileage and about 3k a month?
if any silverado owners read this I'd like to hear what oil filter you've used, and if you know off hand what the numbers for the supertech or fram are?
Hmm...interesting. Looks like they are using the PF47 filter as standard equipment.
Unless you have fitment issues (which you should not), switch to the PF52 filter...it is exactly the same, with the exception of being a few inches long.
I strongly recommend the PF52 AcDelco filter that is available at Advance Auto parts. It is a Delphi manufactured unit, is constructed very well, and on the 4.3L in my 1500 Chevy, has done excelent.
Example...beforehand, I was using the SuperTech and Pennzoil Long-Life 15w40 (truck is a '92 with 100K and bad valve seals...factory standard equipment that year). Somedays I would go out and truck would start excellent, with no "bad" noise. Other days I'd go out, and truck would do the "tick-tick-tick" thing for a few seconds, sometimes even a few minutes. I can only attribute this to a ADBV that was functoning intermittingly.
After doing a good deal of reserach, I decided on the AcDelco I have previously mentioned. Now, every single morning (and in just as cold temperatures) the engine starts up with no tick-tick-tick as at...just purrin' like a cat.
I don't know the extent of your knowledge in regards to these filters, but here are a few pics:
Here is the SuperTech St3980 filter (PF52 cross-reference):
Here is the AcDelco PF52 filter from Advance:
As you can see, the main difference between the two are the Delphi-made AcDelco from Advance has little weld beads on the top as well as having very large holes on the inner tube.
Like I said, it has been performing excellent for me, and I definitely would recommend it to you.
[ February 14, 2004, 10:41 AM: Message edited by: Jelly ]
