Originally Posted By: oldhp
ZeeOSix, Is the ZO6 engine oil bypass in the filter or block?
In the block, but that shouldn't make any difference.
I always thought if bypass was in block it would have greater on effect on oil pressure with no re-guard for high/lower flow filters. Wouldn't the lower flow filter go into bypass sooner and the higher flow filter later if at all? GM used to make a higher PSI bypass spring for SBC/BBC oil filter mounts. I've used them before with and without hi-pressure oil pumps, but always used the 2 quart oil filter.
The oil filter's bypass valve, be it in the filter or in the engine block, operates according to the pressure differential across the oil filter. If a bypass valve is set to 12 PSI, then it will open when there is 12 PSI of pressure difference across the filter.
The delta-p across the filter is a function of the oil viscosity (ie, weight and temperature), and the flow volume going through the filter due to the oil pump output. And also how much debris is caught in the media as time goes on, which will increase the filter's flow resistance.
Guys put a higher pressure bypass valve spring in GM engines when they use a higher volume oil pump, because as mentioned above the flow volume going through the filter is a key factor in the delta-p created across the filter. They were causing more delta-p across the filter by just increasing flow from using a high volume oil pump. If they then used a heavier weight oil, that too increased the filter delta-p. If they didn't increase the bypass valve PSI setting, then with the high volume oil pump it would most likely cause the bypass valve to open a lot more due to increase filter delta-p.
