I promised last year to run several different oil brands, viscosities and dino vs full vs blend. I got super busy w the crazy year. I did follow through but neglected to post. So here it is!!!
Same truck used with same drivers assigned from my fleet. Oil filter was Fram orange can PH10890 changed with each oil change. Each oil change was done only after the OLM reach zero and as quicky after it reached zero as possible. I don't stop a truck mid-shift to change the oil and I never never change early. I always let it hit 0% and then the end of that shift is sent to service department of an oil change. So each change is past the 0% OLM mark between 100-600 miles over.
All of my fleet vehs have Fumoto oil change valves, all oil changes are done while super hot between shifts and oil is allowed to run out until the flow turns into a steady drip. We do this as fast as possible so we never get all of the oil out just until it slows to a steady drip. Oil filters are never pre-filled. Just put on dry with some old oil on the new gasket.
New trucks are never short changed--factory fill always run to past 0% OLM
Air filter was within intervals per restriction gauge and was not change during any of these samples. Air Filter was OEM. Fuel filters changed per Ford intervals.
Bottom line is the OLM is extremely conservative. Fancy, boutique oils and premium filters are a huge wast of money. Short change the oil is of no benefit. Dino F1 Ford approved oil is equally as good as full syn--no benefit for the extra money. Viscosity makes no difference in Florida and hot environments. Buy whatever is cheapest and meets specs. Use cheap filters.
