He's off his rocker (again).
1. If an engine has a fuel dilution problem, how is oil grade going to impact that? How is the oil going to reduce the rate of ingress, which depends on parameters that have nothing to do with the oil?
2. If the result of fuel dilution of the engine oil is that the oil is thinned, and the risk with that is that the oil will become too thin and you will get excessive wear or may toss a rod due to spinning a bearing, why would starting out with an even thinner oil be the correct course of action? It wouldn't be, that would be the complete opposite direction you'd want to be headed, which would be starting with a heavier oil so that you have more buffer against the viscosity reduction.
