Thought Gary,s post would be of interest to posters on this string.
Gary Allan Offline
Loc: Pottstown, PA
Originally Posted By: txrhino
Originally Posted By: G_lo
currently has alot of lifter noise
You probably need to verify the problem; nothing you add to the oil is going to fix a mechanical problem
Well, it typically won't fix anything "broken" ..this much is surely true. If the lifter noise is due to being stuck or fouled/varnished ..or from lack of proper oil distribution along some gallery or rail, then surely something that cleaned up the supply and or the stuck, normally freely moving, part could fix the problem. In terms of HLA noise, I tried just about everything and had pretty much given into just living with it. I just tried ARX for the heck of it. It worked.
Now here's one that I'll let you in on that I was pleasantly surprised by. I have a fellow member that had a totally clean looking engine. I was hoping to do a back up experiment to Dan's two bottle 750 mile test ..but this time do 1000 miles. He pulled the valve cover and showed a totally clean engine. He did a compression check as part of the deal and found two adjacent cylinders were low. After some diagnostics (compressed air with the rockers loose) to determine that the head gasket and valves were intact, we determined that the rings were the problem. A freeze plug between the two cylinders was the cause of an overheat ..and we ventured that this had coked those two cylinder's piston oil control rings. Now the engine had no notable consumption and no symptoms of merit. His compression, after 1000 miles was totally restored on one cylinder ..and came up substantially on the other. He's going to post the entire thing once he's got the rinsing end done with and rechecks the compression. He was another one of my gems of discovery, much like Dan, in that he too was a mild skeptic in the value of such treatments. It's not some "secret" ..but that's about all I want to post for now. I'll leave it to him to post his findings. This one will have the premium of him being an engineer ...so butt dyno isn't in his DNA
_________________________
http://lube-direct.com/gallan/
