I've just bought a low mileage Vitara with the 1.6 NA petrol engine. I would like to do an oil change, as the car did not come with a service book, so I've no idea when it was last serviced.
I've checked the manual for the correct oil recommendation. However, it reads as follows:
"Check that the engine oil you use comes
under the quality classification as listed
below:
• ACEA A1/B1, A3/B3, A3/B4, A5/B5
• API SL, SM, SN
• ILSAC GF-3, GF-4, GF-5"
And it says you can use either 0w20, 5w30, 10w30, or 10w40. But that 0w20 is recommended.
I have no idea what spec oil to go with. It almost sounds like I can use anything. Anyone got any advice on what oil would be best?
I'm not too concerned with maximising fuel efficiency. I would just like the engine to last as long as possible.
below:
• API SL, SM, SN
