Just finished doing what we all love...changing oil !
It was on the wife's '08 Mustang GT, it got Pennzoil Platinum and Motorcraft FL 820S as usual. The reason for the rant...last oil change time for her car, I was overwhelmed with work and stuff around the house, so the wife , meaning well for sure, took the Stang to the local Ford stealership for the oil change. I would never use any of the quick oil change places, but you like to think you can trust the dealer, I guess not. The drain plug was NOT stripped, but it was touch and go for a moment while removing it, I thought it was toast. Now for the filter...even if one is tight, I just use a piece of sandpaper in my palm to give a little grip and it's off. I'm no bodybuilder, but @ 6ft and 210lbs...I'm no wimp either. Not only did the sandpaper not do the trick, I had to come inside , get an old leather belt, and fashion an impromptu strap wrench, along with the kung fu grip with the sandpaper to break it loose ! When I do all the oil changes, the correct wrench on the drain plug and a quick bump is all it takes to remove plug, and you will never need a wrench of any kind to remove a filter I install. Personally, I average over 50k miles a year on my truck, plus the wife's car, son's truck (he does his own, I supervise) and my barn car , and have never had an issue with leaks of any kind. Why ...of why is it so hard for others to understand...more is not always better ??!! Rant over, thanks for listening.
