Originally Posted By: travlnman
Critic, You missed reading that part I guess....at age 43 and millions of miles..I have never needed a wrench to remove a filter that I installed and never had any issues with leaks, so why would any rational human being just keep tightening it ? It is not necessary, it is not better, and it upsets me that common sense is so rare these days it practically a superpower. Filters do not tighten themselves...there is an established procedure for installing a filter, basically what you described in your post, and using that, it will not require any tools to remove. Spin on oil filters should never need any tools to install or remove.That being said....it plainly says "rant" in the title...what did you expect ?
I guess the logic here was better too tight than too loose, right? Of course I fully agree with you that properly tightened is the key. However, as you have seen in the responses, the interpretation of "properly tightened" is subjective.
Originally Posted By: uart
I tighten my filters as tight as I can possibly go by hand and then do an extra 1/8th of a turn by wrench. Yes it's probably unnecessary but I don't care, it gives me a sense of assurance that it wont leak.
So yeah, you'd be unlikely to get one of mine off without a filter wrench, but personally I don't consider them overtightened. I coat the o-ring/gasket of the new filter with fresh oil, I double check there is no stuck gasket left behind. And though I do need the wrench to remove them I've never had an issue with this.
+1
