OIL Catch cans...anybody use one?
The threads are 3/8" NPT. On the mini filter it's 1/4" NPT. I chose to use 90 degree 3/8" NPT to 3/8" barb fittings. Unfortunately, Lowe's or Home Depot don't sell anything but straight fittings, which work fine but I just ordered a 5 pack from McMaster-Carr (don't know why they sell such an odd number). Their website is huge, so I found the page they're located on. Go here:
http://www.mcmaster.com/
You want catalog page 215. Just type "Brass Hose Elbows" then click "find."
Also, if you want the mounting bracket for the filter above you won't find it in the store and need to order it from Campbell Hausfeld's website. They're about $5 plus shipping.
If it's not raining, I'll try to take pics of my setup tomorrow.
mrhonda, I think the VTEC engines get more blowby than the LS engines. Even when my car was stock I'd get oil in my intake. Not huge amounts, but at this point I'd rather not have it in my intercooler.
Here are pictures of the two catch cans I have hooked up in my car:
[ November 28, 2003, 06:53 PM: Message edited by: JPowers ]
JPowers, could you enlighten me as to your turbo setup? Looks super clean. Drag 3? Also, how do you have your catchcan setup hooked up closed loop on a turbo car? Do you just have both your catchcans hooked up to the airfilter pipe going into the turbo inlet?
Oops, looks like a greddy kit! Sounds like you have the catchcan for the PCV going back to the intake manifold? Won't that just close the PCV valve completely under boost and eliminate it's intended purpose?
Thanks man, but it's actually kind of dirty right now.
Greddy pipes don't come polished, so I wet sanded and polished everything by hand. It was a painful experience, and the most painful thing is the dirt and water specs that seem to stick to the aluminum like a magnet. I've searched high and low for a spray on product to just clean the aluminum and not actually polish it and can't find anything. I tried Eagle 1 Nevr Dull and it actually scratched the surface because it's more abrasive than the Mother's Billet I finished it off with. Someone mentioned a product they saw on a truck show, but it's like $150 or something ridiculous. I tried rubbing alcohol and it dulled the surface. There's got to be something. Anyway, sorry to get off topic!
Stock turbo cars come with pcv valves, not just cars with aftermarket kits. I've weighed the pros and cons of keeping the pcv valve and read page after page of information and misinformation. As you already know, when you're under boost, the pcv valve is closed, but when you shift or let off the gas it opens. When under boost, any excess pressure should be relieved through the valve cover breather, but it's important to have a vacuum source here as well if you're running closed loop. Notice the clear braided hose in my picture running from the valve cover to the intake before the turbo, which creates vacuum.
Some claim that retaining the pcv system will promote better ring sealing, but I'm certainly no expert so I can't verify this. Many people simply eliminate the pcv system and run 2 hoses underneath the car and have no problems. Not very environmentally friendly, but the main purpose of this and the Endyn setup is that there's less chance of detonation.
Although inspections only come once a year, keeping the pcv system fairly stock is one less thing to worry about. I just got done putting my catalytic converter back on. The oxygen sensor was seized in the downpipe and I wouldn't be surprised if the person who made the downpipe actually welded it in there. I tried that stuff to free rusty bolts, propane, everything! I finally gave up at 5am, got on the internet to find a cheap replacement, went to bed at 7am, woke up at 10am to find a parts store with an oxygen sensor in stock. The replacement oxygen sensor I bought wouldn't go in because threads of metal from the stock oxygen sensor were stuck in the downpipe, which cost me an extra trip to the hardware store for a tap.
Next year in Pennsylvania, certain counties will no longer just put a sniffer in your exhaust to test your emissions. They'll plug into an OBD2 port. I have an OBD1 ecu with a programmable standalone system and larger injectors which goes in soon to be dyno tuned. This means, next year I'll have to change my injectors, ECU and converter before I can get my car inspected. It's a pain in the arse if you don't have a garage and live in an apartment. Modifying your only car is a stupid thing to do!
Forgot to answer this question. Sorry about the long post! No, the clear braided hose goes from the valve cover to the catch can and then the intake before the turbo. The black fuel injection hose (won't collapse under high vacuum) goes from the pcv to the other catch can and then to the intake manifold.
[ November 29, 2003, 03:04 AM: Message edited by: JPowers ]
What I do with my cars is to plug the intake side of the PCV system, usually at the valve covers. Then run the hot blowby gas through a condensation can located in the fenderwell. This is a baffled 3" aluminum tube ~9" long. It has a spring loaded brass check valve that is pulled shut when there is engine vacuum.
When the car is off or at WOT the valve opens and dumps the condensed blowby gunk. There is a hose which comes from the other side of the baffle on the tube, and goes to the PCV valve then into the intake.
This setup not only keeps a vacuum on the crankcase most of the time (this itself reduces blowby considerably) but also reduces the amount of blowby gas going into the intake by at least 80%.
[ December 08, 2003, 01:03 AM: Message edited by: SHOZ ]
Why not these?
They are totally passive ..will work with either normally aspirated or turbocharged vehicles ..and never have to be emptied. These pull a vacuum on the crankcase using the exhaust stream. Well, let me restate that, they pull a vacuum when the exhaust stream is of a high enough velocity (which would be when the normal vacuum of the CCV/PCV is overwelmed with blowby gasses).
[ December 08, 2003, 10:34 AM: Message edited by: Gary Allan ]
Those look interesting. I'm thinking one on the catback pipe and the connected to the PCV system before the PCV valve.
why would you need a filter inside the can? i thought the heavier particles fall and the air just passes through? wont the filter restrict air?
