Rigged up a catch can
Virginia
Decided after last track days I'd try a catch can to keep what oil goes through the hose to the turbo inlet from coating the charge hoses/pipes/intercooler/etc. Those hoses sweat oil now that I'm running more boost/higher power tune and there is oil residue throughout the intake track so figured anything I can collect is a good thing. This is on my MK7 Golf Sportwagen.
So this is a bit of a rigged-up system - I run a PCV and associated bits from the newer MK8 Golf platform. Main difference is there is a venturi setup off the turbo outlet to feed some charge air through a venturi to produce more consistent vacuum on the PCV vs. just having the vacuum under throttle coming from the turbo inlet/intake air stream. It works well and I have had no PCV-related smoking on track with this setup. I use about 1/4-1/3 qt oil best I can tell per day on track. This catch can works with teh PCV but was designed to be installed in the MK8 Golfs, not MK7. I just swapped sides for install, drilled one hole, bought one bolt, and made a slight bend in the bracket and it worked pefectly. Will be interesting to see how much oil collects on the track next time, I suspect on street it will be min/none. Nice feature is it's all with quick-connect fittings so easy to remove and plug the hose back into the PCV if I wanted. It has a small dipstick and I can unthread the can to dump without having to remove the bracket etc. I'll put a video together on my YouTube detailing all of this sometime in the next week.
https://www.radiumauto.com/VW-MK8-G...hjNPjrjNwJcbRPDngQ_aem_XlswyQ-agxc_aVQLOUraWA
Update. After a month and an autocross...some trace residue in there. I don't expect much from street use. I also think the oil sweat on my silicone charge hoses has dropped off....coincidence? I THINK NOT!
The dreaded catch can. To install, or not to install... Should I?
Also, don't you have to be hyper vigilant with these things in the winter?
Just be careful using them on track. If it's actually accumulating on track, then the g-force from track driving can slosh it towards the vacuum line.
Indeed, then there's the age-old question of why aren't they installed by the manufacturer in the first place? Yes yes I know that one or more vehicles comes stock with one, IIRC some variant of the Mustang.
The Mustang one is an option from their performance division, it doesn't deliver installed from the production line. The stock variations like on Porsche engines drainback to the crankcase, there isn't a tank to drain. (Air oil seperator, not catch can)
You just need to not drive around with it full of water haha.
Maybe depends on the car. Had one on a 5.7 HEMI and it only made a couple ounces of chocolate milk over a winter OCI.
I will get it on track in a month and report on what I collect. Right now after a single autocross and some street use just a tiny bit.
Agreed. I plan on checking after each session.
