garageman402
$100 Site Donor 2026
We have seen the OG Titanium's leaf spring, the bypass valve mount goes deeper into the filter housing than the Endurance's. You don't think that is a weak spot 90 degrees from the ears? There's no chance that "putting a lot of force on the leaf spring ears" onto a flat bench will cause the ears to move outward, thereby creating the arch that produces the gap? If it is in fact a "spring" as you say it is, wouldn't the tension relax when it is removed from the can? Laterally as well as longitudinally? You don't think the can squeezes it to flatten out the arch?It's already been shown that putting a lot of force on the leaf spring ears will not close the gap. The area of the leaf spring around the center tube will not deflect by putting force on the ears, it's too stiff in that area. If a gap is seen when the filter is inspected after cutting it open and a decent force is put on the ears, it will also have the same gap if assembled and never cut open.
Only way to have a good metal-to-metal seal is to have flat and smooth surfaces on both sides of the interface.
Agreed the Endurance seems to have a manufacturing defect in that the "leaf spring" is too thin & weak.
