Ecogard X4610 C&P
BrendanC
$100 site donor 2024
Houston, TX
2012 Honda Accord 3.5L V6 123k miles
in service 5000 miles
out/off: bulk 0w-20 with Ecogard X4610
in/on: 4 quarts Valvoline Restore and Protect and 1/2 quart HPL Engine Cleaner 30 with OG Fram Titanium FS7317
solid filter minus the ADBV, stiff and wouldn’t return to shape.
correct, i don’t buy any nitrile ADBV filters. Silicone only.
If that ADBV failed in 5k they did not get a quality NBR part. This is why I am suspect of overseas suppliers. Originally I was more concerned with the filter media meeting spec. Seems other parts can be an issue. I am sure the U.S. based PGI engineering team would like to know. They were located in West Bridgewater, MA, they may have moved to Taunton.
i’ve seen stiff nitrile ADBV’s in US filters too. stop blaming COO when convenient
Fram makes filters in 2025 that likely have a defective adbv new in the box, and Walmart sells them as ST3614. The adbv may not cover the inlet holes. If the filter is knocked hard enough there is no method to keep the adbv centered even if it accidentally was made right.
I don’t know where the v6 oil filter is located on this Honda, but it may have gotten too hot? Not an excuse for this manufacturer, but they use silicone for better heat resistance.
  • Like
Reactions: GW.
exactly, fram and purolator have all kinds of QC issues that make filters defective from the beginning.
the filter on this car is hanging down near the passenger control arms away from heat. it was strictly oil temperature that did the ADBV in. I added oil to coolant heat exchanger pads on my accords to help take care of oil temps and warm up.
The excuses being presented here for a "forum favourite" brand are shocking.
The only time I was bit by a stiff rubber part was an old NAPA (WIX) jobber with a combo valve.
My fault as the dusty old box was a clue that I should have looked at born on date.
Lesson learned.
Thank You for photos sir.
Lesson learned.
I question combo valves even when they're new. Don't seem to see many around any more.
