This was a run of Red Line 5W20 in the Mopar 2-liter 4 that has NOT been back-spec'd to run 5W20. I used this fill as hard as I can possibly use it since I do not put the car on a track. I pulled a trailer that pushed enough air I was driving flat on the floor for nearly 300 miles, the second half of that in 4th gear (or lower; stick-shift). Then, it sat outside for the winter being started at 25 below zero and driven about 9 miles one-way to work on city streets and county roads. I did get a block heater for it closer to spring than fall. Now, we pull a small boat (somewhere in the general vicinty of 1700 - 1800 lbs total weight, including trailer) up over the hills to the reservoir a few miles east of here. I used a K&N oil filter, new Fram air filter, new PCV valve, and just replaced the plugs and PCV valve (again) within the last couple/few thousand miles. FP60 for the first half of the OCI, and now Renewable Lube's Bio-Plus for the latter part after I ran out of FP60.
Analysis is a Dyson Premium. No comments nor input from Terry will be posted unless he chooses to post it for some reason. I'll only note that he's pretty smart about finding problems before they're problems (hint: I have never seen fuel in a UOA from this vehicle before).
Fe 20
Cu 8
Sn 3
Pb 0
Cr 0
Ni 0
Al 6
Ti 0
Ag 0
Ca 2289
Mg 19
Zn 1494
P 1216
Ba 0
Mo 943
Si 14
Na 34
B 40
K 0
V 0
Sb 0
TAN 2.86
Oxidation 161
Nitration 13
KF water 515
Glycol NONE
Viscosity Index 146
Viscosity (40c) 52.7 cSt
Viscosity (100c) 8.8 cSt
TBN 1.4
Fuel % 1.72
Soot {Below detection threshold}
I won't see this car in UOA any more, as it has been replaced by a Subaru (not sold yet, though, in case anyone needs a very good, reliable, durable, inexpensive used car). However, it will serve its next owner well for a long time if they'll just take care of it regularly. It's too bad because I bought some Renewable Lube 5W30 bio-syn to follow this Red Line. Oh, well...
Fe 20
Cu 8
Sn 3
Pb 0
Cr 0
Ni 0
Al 6
Ti 0
Ag 0
Ca 2289
Mg 19
Zn 1494
P 1216
Ba 0
Mo 943
Si 14
Na 34
B 40
K 0
V 0
Sb 0
TAN 2.86
Oxidation 161
Nitration 13
KF water 515
Glycol NONE
Viscosity Index 146
TBN 1.4
Fuel % 1.72
